Re: Issues with CarPro Ech2o
I have it also same promblem.I've tried many there all pretty much the same.I find ultima being the best as far as gloss and one swipe needed. The last thing I want to do is trying to work with a product that is suppose to be easy and not complex.
I have seen the same thing but for me it's the next day. Looks perfect on the spot but the next morning the streaks are there. I as well would like to try a different product that's multiple purpose like this. The shine is quite amazing thought. I've started to add in other things like cure and that has helped out quite a bit and should add just a bit more protection and stay up with the gloss
Sent from my XT1609 using Tapatalk
Try it as a rinseless, its my favorite period.
I haven't seen this with my Ech2o yet, but Reload with streak if you have an older batch or don't shake it constantly. Next time I use Echo2o I will be more vigilant and check the next day. Overall I like the product, but admittedly if my vehicle didn't have ceramic pro I would still be using ONR, but it's got polymers in it that will harm your coatings beading properties. Unfortunately. I hope you find the right solution!
It may be that you are dry wiping, by not using enough product. Try misting the towel and then come back with a dry towel. Seems like I need to use more product during the summer than the winter.
I have only had issues with ech20 on hot and humid days. Good thing humidity is not an issue here in Southern California. Other than that I have no issues with it.
Quote:
Originally Posted by
The Guz
Thanks Guz. May I ask what dilution ratio you've been using?
i too second so cal being ideal all the time weather wise! lol
but i used to have streaking, i since went to a 1oz to 20 ratio for waterless and it has been perfect. its better as a rinseless IMO though. You should try Gloss Shop Trifecta, Ultima Acrylic, and Wolfgang Uber those are some real good ones not as finicky as echo.
Whoa whoa whoa, I'm SoCal but 112 degree weather does not make things fun..lol
