Looking to upgrade from the PC
Looking for recommendations on a new DA. Would keep the PC in use but as a dedicated 3". Pads I have on-hand are 5.5' Hybrids and 5.5" Thinpro's. Would be hard for me (not saying impossible) to buy all new pads to accommodate a new DA, but it would take some time. Have been doing my best to read as many threads as possible when DA's are talked about but I know I've missed plenty. So if you were to jump up from a PC, what would you get and why? Pro's and Con's?
Open to any of these:
Flex 3401
Griots Boss
Makita
Rupes
Greatly appreciate your feedback....
Gene
Re: Looking to upgrade from the PC
Will read the replies with great interest. Doubt I can justify an upgrade over my GG6, which is more than adequate for my non-pro needs. But interested in what I would move to.
Those who recommend an upgrade, would be great if you could specify 15 or 21 and why. Not clear to me which I would want.
Quote:
Originally Posted by
schambers
Flex 3401
Griots Boss
Makita
Rupes
Gene
I started with the PC and still use it. I use the 3" and 4" pads and use it mainly for my LSP step. I looked and was considering many DA's, however, I went with the Flex 3401. The reason being because it was the only "forced Rotational Orbit" DA (that I assume has changed). All others were free float and not to say anything wrong with them, they are ALL free floating DA's.
To me it was the best thing I did for upgrading. The Flex is a Beast and can tackle any detailing with ease and can complete any compound/polishing in 1/2 the time. It will keep on going even on a curved panel (work on a Porsche 911 for example) and chug away. Again, that is me. I do not know what you want to accomplish, however, that would be something I would seriously consider.
I know there is the Boss, Rupes and many others, but I would look into this one as something you should put on the top of your list.
Rupes or Flex 3401.
Even the Duetto from Rupes is a pretty significant jump in performance. I personally can't see the advantage other the 21 over the 12 at this point. The shop I help out has the 21 molded.
The Flex 3401 features gear driven, forced rotation. It's kind of like a rotary buffer, but a lot easier for the novice.
They're definitely pro grade tools, and help in the journey to beautiful paint. They're both smoother, and quiter.
My vote would also be Rupes. Great tools and a complete polishing system. With all the pad and polish choices Rupes makes it easy even for non pros.
Yeah, this is kind of a "read, read, and read some more" to make your choice type of deal.
All depends on your personal needs.
get the BOSS G15 or G21 (both these can use their interchangeable 5" & 6" backing plates which will allow you to use different size pads), keep the PC dedicated for the smaller pad setup...
https://www.youtube.com/watch?v=FtpgZV9vL1A
https://www.youtube.com/watch?v=i8eIKCHq72A
I would suggest a rupes 15 mk II. It's a great machine, powerful, smooth but also you can use your thin pro pads. A lot of people will suggest getting the whole rupes system but I'm personally not a fan of rupes polishes. I prefer less oily and more water based but again, personal opinion.
