step between clay and opti-seal (or klasse)
I have been lurking here for a few days learning about how to properly wash and care for my car. The car is a few years old and I've mostly neglected washing and waxing, etc.
I'm trying to change that now, and I know how to do a proper two-bucket wash. I am also planning to aggressively clean the wheels which have a lot of baked-in brake dust (hopefully Iron-X and Meguiars APC+ will do the job). My question is what to do after washing to give the paint a bit of protection that will be relatively low maintenance.
My first plan was to Iron-X, clay (Meguiar's blue clay with ONR as lube), then use Klasse AIO, Klasse HSG and finish with a wax (maybe Optimum Spray Wax or P21s).
Reading more, I thought to use Optimum Opti-Seal instead of Klasse HSG would work better because it would be easier to apply, last as long, wouldn't require wax on top, and could be used on the wheels as well. But what should I use between clay and the Opti-Seal? Is Klasse AIO still a good choice?
(I know about Opti-Coat, and I think I might use it in the future. But there are lots of swirl marks, scratches, etc and I think I need to do a lot of correction before using something that permanent.)
Thanks for your thoughts!
Re: step between clay and opti-seal (or klasse)
Quote:
Originally Posted by
yamad
Once your done with any LSP then follow up after your washes with BLACKFIRE Wet Diamond Polymer Spray or Optimum Instant Detailer & Gloss Enhancer. This will ensure you the best protection and shine after every wash.
:welcome: To Autogeek Online!! :props:
yamad
This link will take you to some fabulous articles written by Mike Phillips.
Articles by Mike Phillips
Basic steps in order are:
- Wash
- Clay
- Paint Correction & Polish
- Seal
- Wax
Wheels
When dealing with neglected wheels give them a thorough cleaning with a quality wheel cleaner.
- Meguiar's Wheel Brightener
- Poorboy's World Spray & Rinse
- SONAX Wheel Cleaner
Once the heavy grime and dust is out of the way give the wheels a good spray with CarPro IronX, let sit, then scrub as directed..
yamad
Wash the car thoroughly with your favorite car wash.
While still wet spray with CarPro IronX. This will attack iron based particles stuck to the finish. This is an important step to decontaminate the finish prior to claying.
Clay the finish using the Meguiar's clay you mention. It's a great clay and does a beautiful job removing embedded particles prior to the next step.
Polish - Klasse All-in-One is a chemical cleaner and although it does a great job it has no correction capabilities.
Instead of using Klasse All-in-One, perhaps consider something like Sonus Swirl Buster Polish or comparable product.Combine Sonus Swirl Buster with an Orange or White foam pad and a dual action polisher and you won't believe how great it leaves the finish.. This will remove swirls, oxidation, and grime....
Seal - Optimum Opti-Seal is an easy to apply clear sealant. Although Klasse High Gloss Paint Sealant is a superb product it can be finicky to apply and remove easily. Optimum Opti-Seal being clear is so easy to apply and don't worry about hazing and buffing as there's no dust whatsoever..
Use two coats of sealant applied as directed and add a carnauba to add wetness and depth if so desired...
Sealants
KAIO is a great product - good cleaning, easy to use, and can be used on most everywhere of the exterior. You can definitely still use it as prep prior to Opti-Seal. I would still consider getting OCW - it takes as little time to use as a QD during your drying process, but it will add real protection.
Bobby G, thanks for the detailed answer.
I was trying to avoid doing any major correction for this first pass because I am still considering handing over the correction work to a pro. Can the Sonus polish be applied by hand? One advantage of the Klasse system for me was that it sounded like something that could be done by hand (without a requirement that I learn to use and invest in a DA polisher). It was my impression that compounding and polishing was a PITA without a machine, so I had so sort of given up on the idea of getting rid of all the swirls for now.
thanks to all the responses so far. I've realized that what I'm actually asking about is whether Optimum sells a specific cleanser/polish intended to come before OOS. It seems like many of the sealants/waxes have a dedicated cleanser/polish that comes before it (Ultima Paint Prep+ --> Ultima Paint Guard+). Of course, maybe I should just go with one of these predetermined systems and be done with it. It just seemed as though Opti-Seal was particularly well-reviewed.
From all your responses, it looks like the full-out detail session should be something like:
1) wash -- Optimum
2) clay -- Meguiar's
3) polish/cleanse -- ?
4) seal -- Optimum Opti-Seal
5) wax -- Optimum Spray Wax
Maintenance washes would be:
1) wash -- Optimum Car Wash or ONR or UWW+
2) quick detailer -- Optimum Instant Detailer (or UWW+?)
(p.s. I'm not overly wedded to optimum, but it seemed like a good idea to stick with a system of products)
You can use Optimum Poli-Seal or Optimum GPS as your polish/pre-wax cleaner.
jminrod
To Bobby G below is link to a kit I bought on Craigslist and I think I read u said there is no cut just wanted to verify if that applies to this kit. I was thinking of using it on a clients car that is pretty clean and just wanted to know for sure.
http://ep.yimg.com/ca/I/autogeek_2221_125814131
Klasse makes a fantastic combination. Klasse All-in-One is a chemical cleaner that removes oxidation, grime, stains leaving the finish looking bright and radiant. Klasse All-in-One also leaves behind a sealant for added protection.
These products were developed over 30 years ago and will hold their own against anything they come up against when used together...:props:
This is from the Klasse page on Autogeek - Klasse ALL-IN-ONE Auto Polish, Klasse All In One, klasse aio, Acrylic polish
Klasse All-in-One
Acrylic is the Solution. Unlike most car waxes or sealants, Klasse All In One is acrylic-based. Acrylic is different than wax, silicone's, and polymers. The Klasse All in one polish will bond to your car’s surface just like the previously mentioned treatments, but it will not cause any change to your paint, and you don’t have to worry about drying time. Klasse All In One dries as fast as you apply it, and there is no risk of hazing or streaking. Klasse All-In-One contains no abrasives or silicone's, and does not stain plastic, vinyl or rubber trim. It can be used on any non-porous surface, and in addition to car care it is also approved for marine and aviation use.
The Klasse kit you bought will impress you....and your client.
yamad
Yes it can but correcting swirls by hand is a tough time consuming process and the consistency will vary much more than if performed with a machine..
If you choose not to go that route just skip this step...
Polishing Paint by Hand
Foam Applicator Pads at Autogeek.net
Priming your pad when working by hand
Removing Scratches By Hand
How to use a hand applied abrasive polish or paint cleaner by hand
1-Step versus 3-Step Process by Hand
Man versus Machine
