What's in the box? NEW Griot's BOSS 15mm & 21mm Long-Stroke Polishers
Using the Griot's BOSS 15 Long-Stroke Polisher on a 1973 Chevy Z28 Camaro
http://www.autogeekonline.net/galler...BOSS_15_21.JPG
Griot's Garage BOSS 15mm & 21mm Long-Throw Random Orbital Polishers
http://www.autogeekonline.net/galler...S_15_21_38.JPG
From the manufacturer
What the BOSS 15 and BOSS 21 have in common
• Powerful 1100-watt, 10 amp motor, delivers the torque to maintain consistent pad rotation for advanced paint correction.
• Suit the speed to your need 6 speed settings.
• Speed dial accessible for right- and left-hand users.
• Fully variable speed trigger throttle with trigger lock.
• 10-foot quick-connect 16 AWG SJO rubber power cord
• Both polishers can use either a 5” or 6” Pad system interchangeably.
Where the BOSS 15 and BOSS 21 are different
BOSS 15
• OPM Range = 3000 - 5300
• Orbit stroke length = 15mm
BOSS 21
• OPM Range = 3000 - 4500
• Orbit stroke length = 21mm
The NEW Griot's BOSS 15mm & 21mm Long-Throw Random Orbital Polisher
http://www.autogeekonline.net/galler..._15_21_001.JPG
So let's take a look at what is inside the box...
http://www.autogeekonline.net/galler...S_15_21_02.JPG
First - everything that comes in the box is the same - so I'm just going to walk through what comes in the the BOSS G15 polisher and the items in the box.
In the box are the tool, zippered nylon storage bag, informational chart showcasing the tools and related pads, products and accessories.
http://www.autogeekonline.net/galler...S_15_21_03.JPG
Here's the polisher, the owner's manual, everything that comes in the nylon storage bag. The backing plate comes attached but I've removed it in order to showcase the various benefits and features of the tool and backing plate.
http://www.autogeekonline.net/galler...S_15_21_04.JPG
The nylon zippered pouch ensures you don't LOOSE the little stuff...
http://www.autogeekonline.net/galler...S_15_21_37.JPG
Be sure to fill out the warranty registration card and mail it into Griot's to register your tool for the warranty.
http://www.autogeekonline.net/galler...S_15_21_05.JPG
http://www.autogeekonline.net/galler...S_15_21_06.JPG
The owner's manual is well written and includes all the pertinent information you need for operating the tool safely.
http://www.autogeekonline.net/galler...S_15_21_07.JPG
This is actually a diagram in the owner's manual pointing out the location of the various components.
http://www.autogeekonline.net/galler...S_15_21_08.JPG
These are called "Tool Rests"
You might think it's no big deal but without a tool rest, every time you set your polisher down, without it - the polisher will roll over onto it's side. If you're new to machine polishing you might not know this, but as you work around a car you set your polisher down a LOT. And because these are soft rubber you can set them down on a painted surface safely.
http://www.autogeekonline.net/galler...S_15_21_09.JPG
The rear tool rest is simply the soft rubber portion of the tool body.
http://www.autogeekonline.net/galler..._15_21_09a.JPG
Dual access Speed Dial - Very cool feature, works great for adjusting speed-on-the-fly whether you're right-handed or left-handed.
http://www.autogeekonline.net/galler...S_15_21_10.JPG
http://www.autogeekonline.net/galler...S_15_21_11.JPG
Carbon Brush Inspection Cap - These can be removed using a flat head screwdriver to enable you to inspect or replace the carbon brushes.
http://www.autogeekonline.net/galler...S_15_21_12.JPG
Contaminant Protection Screen - Keeps dirt, dust and debris from getting inside the tool body.
http://www.autogeekonline.net/galler...S_15_21_13.JPG
These can be removed and cleaned.
http://www.autogeekonline.net/galler...S_15_21_14.JPG
Variable Speed Trigger Throttle
http://www.autogeekonline.net/galler...S_15_21_15.JPG
Trigger Lock Button - So important to make it a habit to lock your trigger when buffing for hours.
http://www.autogeekonline.net/galler...S_15_21_16.JPG
Vented backing plate
The air vents allow air to be flushed through from the tool body through the head of the polisher and out through the face of the pad.
http://www.autogeekonline.net/galler...S_15_21_17.JPG
http://www.autogeekonline.net/galler...S_15_21_18.JPG
Cross-drilled face - allows air ventilation
http://www.autogeekonline.net/galler...S_15_21_19.JPG
Velcro-free lip
This enables you to EASILY grab the edge of your buffing pad to get it started to pull the pad off. Genius. :xyxthumbs:
http://www.autogeekonline.net/galler...S_15_21_20.JPG
Here's the reciprocating components including the counterweight, spindle, bearing and housing.
http://www.autogeekonline.net/galler...S_15_21_21.JPG
The Griot's BOSS tools use high quality sealed bearings
http://www.autogeekonline.net/galler...S_15_21_22.JPG
This is the bearing...
http://www.autogeekonline.net/galler..._15_21_22b.JPG
Technique Tip
When attaching the backing plate to the spindle, both have a rectangular slot with rounded ends.
http://www.autogeekonline.net/galler...S_15_21_23.JPG
http://www.autogeekonline.net/galler..._15_21_23c.JPG
In order to take out any guesswork and make sure you have the backing plate flush to the spindle - take and place a black mark using a Sharpie Marker in-line with the direction of the length of the rectangular slot on the back side.
http://www.autogeekonline.net/galler...S_15_21_24.JPG
http://www.autogeekonline.net/galler...S_15_21_25.JPG
This is FLUSH
http://www.autogeekonline.net/galler...S_15_21_26.JPG
Then insert and tighten down the backing plate bolt with the include hex head wrench.
http://www.autogeekonline.net/galler...S_15_21_27.JPG
Also in the box...
Below are pictures of the factory bolt, two weighted bolt options, a 5mm hex head wrench and replacement carbon brushes
http://www.autogeekonline.net/galler...S_15_21_28.JPG
Weighted Bolts
The silver bolt on the left is the factory installed bolt. The black and gold bolts are tuning bolts.
http://www.autogeekonline.net/galler...S_15_21_29.JPG
Air intake vents
These are to cool the inside of the polisher head and all the reciprocating components plus the backing plate and pad.
http://www.autogeekonline.net/galler...S_15_21_30.JPG
Double-shot rubber overmold for easy gripping and increased stability while holding and operating the polisher
http://www.autogeekonline.net/galler...S_15_21_31.JPG
http://www.autogeekonline.net/galler...S_15_21_32.JPG
http://www.autogeekonline.net/galler...S_15_21_33.JPG
http://www.autogeekonline.net/galler...S_15_21_34.JPG
Finger grooves in the forward facing rubber overmold on the head of the polisher
http://www.autogeekonline.net/galler...S_15_21_35.JPG
A very well thought-out polisher that includes everything you need in the box to get started fast.
http://www.autogeekonline.net/galler...S_15_21_36.JPG
My comments...
Like the first generation BOSS polishers, the new BOSS polishers are improved and refined. Griot's has taken an already proven tool design to an even higher level of performance and reliability. If you're still working by hand, make the jump to machine polishing. Not only are the Griot's Garage BOSS 15mm and 21mm Long-Throw Polishers safe and easy to use - they make working in your garage - on your car - fun!
Plus a complete line of buffing pads, compounds and polishes to maximize the ability of the BOSS polishers and enable you to tackle anything in your garage.
On Autogeek.com
Griots Garage BOSS G15 Long-Throw Orbital Polisher
Griots Garage BOSS G21 Long-Throw Orbital Polisher
All Griot's Products
All Griot's BOSS Tools, Pads and Products - Plus 4 BOSS videos for more info!
Re: What's in the box? NEW Griot's BOSS 15mm & 21mm Polishers
More...
Recently Rod Kraft from Griot's was our guest to discuss in-depth, all of the new and existing Griot's Garage polishers.
https://youtu.be/MQB-8evjsIo
At the 14:50 Time Stamp, Rod Kraft explains in detail the design idea behind the weighted backing plates bolts. The entire video though is filled with lots of meaty information about not just the tools but also the new microfiber pads and the BOSS abrasive technology.
:dblthumb2:
Cool..what generation are these Boss machines?
nice, thanks for sharing! :props:
Great write-up Mike.
I really enjoyed the video with you and Rod back when it first aired.
Good stuff. :props:
If these perform as good as the G9 we used at the detailing class, I may need a new tool....
Quote:
Originally Posted by
Spikey Mike
You know damn well you're gonna get one, Mike. Just get it over with............:laughing::laughing:
Would like to hear your thoughts on this generation of polishers vs the previous generation. Also, didn't they do away with the BOSS name?
Glad I’m not the only one who still marks backing plates.
Spikey Mike
I grabbed the G15 during our last polishing session and gave it a try, Rod was packing it up at the end of Saturday for his return. Not leaving it for Mike Phillips to test out.
Yes Spikey Mike, if you are needing a corded 15mm (or the 21mm) long throw with tons of power, smooth, perfect for most hands, lifetime warranty, and half-price compared to RUPES, then this is your next purchase.
I have heard that Griot's did have a bad batch of first-run machines due to the backing plate and stopped their production. GG stands behind the product and anyone with it were given full warranty. These latest units are supposed to be corrected and from my light use, they are good to add in your tools of choice.
This was the best photo review I have seen on those machines. Mike Phillips did take time to record just about everything one could even do without doing a complete tear down of the machine and voiding the warranty. I'll let GG team give us those insights.
Spikey Mike, put either one on your Santa list and give it your bride.
