I have a tan/beige dash that had a hard shell cover over it. The shell was glued down with feels like silicon (soft rubber texture).
How do I remove this glue without affecting the original dash colour?
Now
Attachment 73633
Hopefully will be
Printable View
Now
Attachment 73633
Hopefully will be
Why did you remove the shell?
Because I am trying to get it back to original. The shell was just that, a hard fiberglass cover. Somebody who might want to purchase the vehicle will be turned off.
If I can't get it to look decent I might have to put the shell back on.
The glue I believe is a silicon glue as it is very soft, pliable and non staining. The owner is in France and may not be alive. I don't think he put it on because the interior was black when I bought it and the leather was stiff and definitely needed replacement which I have done and the dash is the last remnant of the black interior that was not original.
Maybe heavily coat it with some sort of moisturizing vinyl & plastic protectant, let it set overnight. Perhaps the next day the protectant will have made it's way under the adhesive, weakened the bond, and you can slowly pull the adhesive off?
Alternatively, heat it up with a heat gun? Maybe it will soften it, and you can slowly pull it off? I know heat often works to loosen up the adhesive on labels so they can be peeled of without leaving residue. Maybe that'll work here, too. Just, you know, try to not melt things.
Try white vinegar (5%), using a soaked cloth to saturate the silicone.
