Re: keeping wax in fridge
I think it's more likely that your products have shrunk from solvent evaporation rather than cool temperatures in your basement. I'm not sure if people refrigerate their wax to slow the evaporation or for another reason.
This is way off topic but after 20 years I figured out what keeps my big caulking tubes of GE II silicone in perfect shape for years....keep em in the fridge!
Tim,
It's a proven fact that cold temperatures causes shrinkage.......;)
Quote:
Originally Posted by
Setec Astronomy
well that's not good. I'm gonna stick them in some ziplock bags tonight...
Tim...
I, too, am sorry to hear of your shrinkage issue. :(
With that being said...
Since I'm still in the process of putting on my "winter coat" (better known, according to the Wifey, as belly-fat) I really don't have room in the fridge for much of anything, except for vittles, of course.
:D
embolism
I'm not sure that will really do it, I believe a standard bag like that will probably be permeable to solvent vapors.
Perhaps the idea (for refrigerating) is to avert temperature fluctuations when storing the wax for prolonged periods of time. I'm sure regular daily temperature variations can degrade certain qualities of the wax over the wax’s life.
I know here (TN) in the summer time, the garage can have up to a 20*F to 30*F variance in temperature. When the wax is only used maybe one time a month (depending on how many vehicles you own and whether or not you use other waxes), that is quite some span of time that the wax is being stored in unmanageable environment.
At least if the wax is kept in the fridge, the temperature variances are much lower depending on if the wax is kept in a crisper/drawer, and how many times the refrigerator is opened, and for how long the refrigerator is open. Plus these independent variables are easier to control, so long as the power doesn’t go out.
Im the MAN
shrinkage hehe
I've always kept my stuff in the basement (in a room with no outside facing walls) which is normally cooler than the rest of the house
I think I've got some press and seal lying around that I'll wrap around the container openings. Hopefully that'll do the trick. It's how I store my dr. colourchip and it seems to be working thus far.
Unless I find a minibar at the side of the road I don't think the missus would take kindly to me buying something to store my waxes. And if I put them where the vittles are kept then I'd probably just as soon find them in the composter or recycle bin...
I found the absolutely perfect environment for storage of detailing products.
A wine storage cabinet.
I found one being thrown out on the curb last year. It was a huge 108 bottle cabinet. They threw it out because the glass in the door was broken. I dragged it home and tested it and the door was the only thing broken. I replace the glass with an insulated panel and pulled out the wine rack. It stays at 55 degrees and 65% humidity
I did have to add freon to the system after about six months. It took 3oz of r-134
