How To Use The Cyclo Polisher
About Cyclo Polishers
Cyclo polishers are risk free, even for first time users. With their dual, counter-rotating, and oscillating buffing heads, you cannot burn the paint or instill swirls. Cyclo polishers are the easiest polishers to control, even with one hand. They are vibration-free and lightweight. No other tool even comes close. Plus, they are versatile. You can polish paint, scrub carpets, and even leather seats. Cyclo polishers offer legendary durability.
You use a Cyclo Polisher pretty much like any other dual action polisher and that is,
- Divide larger sections of a panel into smaller, more manageable sections.
- Buff out one section at a time using overlapping passes and a crosshatch pattern
- After you finish one panel move onto the next panel
Here's my demo truck, an extremely neglected Chevy Tahoe that's been repainted at one time in it's life. This truck sit outside 24 x 7 and rarely if ever receives any exterior maintenance including washing.
http://www.autogeekonline.net/galler...loShots001.jpg
There's water spot stains and oxidation with light swirls and scratches...
http://www.autogeekonline.net/galler...loShots002.jpg
Close-up - the paint actually has a texture to it it's so rough...
http://www.autogeekonline.net/galler...loShots003.jpg
First up I'm going to remove the above surface bonded contaminants using Detailer's Universal Detailing Clay and Universal Clay Lube.
http://www.autogeekonline.net/galler...loShots004.jpg
Using lots of clay lube as the finish is like asphalt...
http://www.autogeekonline.net/galler...loShots005.jpg
The contaminants are just off this one section of paint...
http://www.autogeekonline.net/galler...loShots006.jpg
Here's what I'm going to use, the Cyclo Pro Model 5 Variable Speed Polisher with Yellow Foam Cutting Pads and Green Polishing Pads.
http://www.autogeekonline.net/galler...loShots007.jpg
The yellow foam cutting pads are primed and I've placed a couple of drops of product on each pad...
http://www.autogeekonline.net/galler...loShots008.jpg
Here I'm making slow, overlapping passes in two different directions on the 5 speed setting which is the highest speed setting.
http://www.autogeekonline.net/galler...loShots009.jpg
Front to back...
http://www.autogeekonline.net/galler...loShots010.jpg
Side to side...
http://www.autogeekonline.net/galler...loShots011.jpg
Next up I will polish the same section at the same speed setting using the same technique...
http://www.autogeekonline.net/galler...loShots012.jpg
http://www.autogeekonline.net/galler...loShots013.jpg
http://www.autogeekonline.net/galler...loShots014.jpg
Next I'm going to machine apply the wax only I'm turning the speed setting down a little...
http://www.autogeekonline.net/galler...loShots015.jpg
http://www.autogeekonline.net/galler...loShots016.jpg
The tool is well balanced, lightweight and easy to use even with one hand...
http://www.autogeekonline.net/galler...loShots017.jpg
Laying down a thin coat...
http://www.autogeekonline.net/galler...loShots018.jpg
I let the Pinnacle Souveran Liquid Carnauba Wax dry till it swipes clear...
http://www.autogeekonline.net/galler...loShots019.jpg
Then carefully wipe the wax off using good technique...
http://www.autogeekonline.net/galler...loShots020.jpg
http://www.autogeekonline.net/galler...loShots021.jpg
Now carefully pull the tape-off at an angle...
http://www.autogeekonline.net/galler...loShots022.jpg
Here's before and after results...
http://www.autogeekonline.net/galler...loShots023.jpg
http://www.autogeekonline.net/galler...loShots024.jpg
http://www.autogeekonline.net/galler...loShots025.jpg
http://www.autogeekonline.net/galler...loShots026.jpg
Working section by section
If I were to continue buffing out this hood I would probably divide it up into sections along these lines....
http://www.autogeekonline.net/galler...loShots000.jpg
Here's the extent of the products I used. I kept it simple and restored the paint to as good or better than after it was painted...
http://www.autogeekonline.net/galler...loShots027.jpg
On Autogeek.net
Cyclo Polishers and Accessories
Pinnacle Polishes and Waxes
Detailer's Car Care Products
Re: How To Use The Cyclo Polisher
