The cost for the upgrade straight from Griots was worth it to me...even though I could have VERY easily installed my own separately bought extension cord to the interior of the GG6 I figured why risk the warranty? Griots will replace it whenever something goes wrong and to me that is worth more than saving $6-8 buying my own extension cord and installing it.
"Dirt likes detergent so much better than the surface that it's attached to, it'll leave that surface to go hang out with the soap"...aim4squirrels
To help all those who find themselves faced with this question, I wanted to provide you side to side comparisons of the options.
As you can see there is a definite gauge difference in the regular version and HD cable
Not to mention the additional length definitely makes it nicer as draping the cord over your shoulder alone will take-up several feet of cable
In my opinion, the HD cable is what you want as the standard version almost feels like a cheap alternative to what was originally designed for the unit. By that I mean it is my opinion that whatever engineer designed this piece originally had intended for the power cord to be the thicker gauge (but maybe not that exact length) as it feels more substantial and in line with the perceived quality of the tool. The thinner gauge cable just feels inadequate.
Doesn't the thicker cable just appear to fit better.
All in all though, once you get past the cable, it is all the same. I have taken both apart and beyond the cable the devices are exact twins in every regard.
If I were you, you've come so far as prepping yourself to spend the money, go the extra $15 and you won't regret it.
*note* - There is a color difference in the shade of red, but I think that is simply due to whoever dyed the plastic that day on the assembly line as it clearly does not differentiate in any way.
The reason the 25' cable is thicker than the 10' cable is a simple matter of less current drop due to length. It doesn't ADD any performance or is it a higher performance model. You can do the same thing with the proper gauge extension cable. Having said that, the 25' cable is only a few dollars more and will save you time hunting down the proper gauge extension cable to prevent any drop in current (voltage or what have you). Personally, I'd go for the HD version, but, keep in mind it's only the cord and nothing more.
