Results 11 to 20 of 26
    In time out
    Mar 2013
    Los Angeles, CA
    4,845
    Re: Recommend Pads and backing plate for 7424(non-XP)
    Quote Originally Posted by Rmd View Post
    I would stay away from the Meg's MF correction system on a 7424. I tried that approach when my only polisher was a 7424, and the machine wasn't up to the task of spinning the pads. I bought a GG6 after that and the Meg's MF system worked well for me. I use my 7424 with a 3.5 backplate and 4" pads now, and it's ok for that.
    Could not disagree more
    The Megs DAMF pads are perfectly suited for the lower torque of the PC
    If you have poor technique and do not keep the pad flat to the paint, it will bog down
    Mark your backing plate, to make sure it is not stalling out
    I suggest machine speed of 5-6 with a PC for all pad sizes. Be careful with 3-4" pads at these higher speeds...if you don't keep the machine planted to the paint; they will go flying
    I agree that there is very little that can't be polished with a 4" pad, but I do have the Megs DAMF 3" cutting and they cut very well on the PC
    Resist the temptation to use a rotary BP with DA pads. Eventually, you will burn up the pad, backing plate or both
    Super Member VISITOR's Avatar
    May 2007
    9,728
    Quote Originally Posted by allenk4 View Post
    i do not like to use a rotary backing plate with a DA screw with use on the DA. IME the backing plate becomes loose from the screw and i don't feel comfortable for fear of damaging the paint if it comes/flies off. the best thing to do but might be a little pricey is to get an exact-fit custom DA backing plate from (kevin) buff daddy. he can make just about anything...
  3. #13
    Super Member builthatch's Avatar
    May 2008
    east coast
    2,352
    i put red thread lock on a thread or two of my adapter. i never had any issues but just looking at it when i first got the parts, it seemed like a possibility so i eventually got paranoid enough to use thread lock. i have had the plate long enough that AG doesn't even sell it anymore and it hasn't yet come loose. i had to take it apart only once to actually use on my rotary for a particularly challenging headlamp project and didn't have much of an issue, but i did reapply the thread lock when it went back to DA duty.
    regardless, it looks like LC makes more than enough sizes at this point where you can just get a DA plate for anything.
  4. #14
    Super Member dlc95's Avatar
    May 2013
    Rochester Hills, Mi
    6,016
    +1
    It was my understanding that system was specifically designed to use with that style machine. I never have issues spinning Rupes Microfiber pads, or Lake Country thin foamed wool on the pc.
  5. #15
    In time out
    Mar 2013
    Los Angeles, CA
    4,845
    +1
    You are correct, Sir
  6. #16
    Super Member refreshauto's Avatar
    Feb 2014
    Odessa, TX
    1,158
    Thin pads is what you want to go with using the PC
  7. #17
    Super Member DiPaoro's Avatar
    Feb 2009
    338
    Will the wool cut deeper than the yellow?
  8. #18
    In time out
    Mar 2013
    Los Angeles, CA
    4,845
  9. #19
    Super Member Rmd's Avatar
    Dec 2012
    Orange County, CA
    713
    Kyle - do you prefer to use your 1st gen 7424 when using the 5" or 6" DAMF pads as opposed to a PCXP or Griot's? I forget which other polishers you brought to the last SoCal meetup.
    Honest question. Not trying to start a debate on your above quote. My experience has been different.
  10. #20
    In time out
    Mar 2013
    Los Angeles, CA
    4,845
    Since I purchased the FLEX, I can't imagine compounding an entire car with a PC
    That being said, we have both corrected plenty of deeper defects down at Meguiar's HQ using the Megs machine with DAMF, so we know it works, just a bit more slowly
    If I had to compound with the PC, I would definitely go with the 5" Megs DAMF with D300 or M100
    I love my PC with 3" & 4" pads, especially the 3" DAMF
  1. 7424 Backing Plate Question
    By swanicyouth in forum Auto Detailing 101
    Last Post: 06-20-2012, 02:43 PM
  2. Backing plate for sanding with the 7424
    By goathead in forum Porter Cable 7424XP Dual Action Orbital Polisher
    Last Post: 07-29-2011, 11:27 AM
  3. 3 inch Backing Plate & PC 7424
    By gatoman39 in forum Ask your detailing questions!
    Last Post: 04-30-2011, 12:13 AM
  4. Replies: 4
    Last Post: 06-18-2010, 08:12 AM
  5. New backing plate and pads for 7424?
    By jmy2469 in forum Porter Cable 7424XP Dual Action Orbital Polisher
    Last Post: 09-16-2009, 09:43 AM
