Page 4 of 4 FirstFirst 1234
Results 31 to 37 of 37
  1. #31
    Mar 2014
    Re: Harbor Freight cord Mod
    just finished doing this mod (plus the switch rotation mod and grease mod), i can't believe how good it looks. Thanks for the great write up.
  2. #32
    Oct 2013
    386
    I need to find a 15+ foot rubber cord like my Flex has. My Rupes is a piece of crap cord wise, tangles every time I look at it.
  3. #33
    Super Member ski2's Avatar
    Dec 2011
    Southwest PA
    1,826
    Quote Originally Posted by arisking View Post
    I found that if you go to a small independent hardware store (if you can find one) they usually have bulk soft rubber 2 or 3 way cord so you can just pick out an appropriate plug and make your own cord.
  4. #34
    Mar 2014
    Columbia, SC
    71
    Thanks for the write up! Will check this out as well..
    Don't mean to hi-jack..
    I checked out this thread http://www.autogeekonline.net/forum/...er-new-45.html
    for the HF DA polisher mods.
    I went ahead and removed all the factory grease and replaced it with red hi temp disc brake wheel bearing grease i had from work.
    The polisher is much quieter, but I don't remember the vibration being so bad?
    This is my first time using a DA polisher, does/do these machines vibrate quite a bit?
    Thank you
  5. #35
    Mar 2014
    Quote Originally Posted by Oceans05 View Post
    Thank you
    Did you put the backing plate back on yet? Mine went from quite a bit of vibration before the grease mod to virtually no vibration at all after the mod. But if the backing plate isn't installed, the balance won't be correct.
  6. #36
    Mar 2014
    For anyone that destroys the cheap phillips head screws when taking the gear head apart, they are M4x0.7 x 16mm. They sell them at Home Depot, 4 to a pack for $1.05, with hex heads so they won't strip out.
  7. #37
    Super Member CDot's Avatar
    Aug 2013
    1,010
    Quote Originally Posted by jdoublehcubed View Post
    Good look!
  1. Harbor Freight DA
    By Balthezor in forum Auto Detailing 101
    Last Post: 09-28-2017, 11:06 PM
  2. TWO Harbor Freight DA's
    By cruzncali in forum Auto Detailing Tools and Accessories
    Last Post: 02-27-2016, 11:15 PM
  3. Harbor Freight
    By 997911 in forum Product Reviews
    Last Post: 03-20-2013, 11:15 PM
