Results 1 to 8 of 8
    Super Member DetailKitty's Avatar
    Jul 2013
    PA
    5,026
    Any advice for someone starting out on one of these?
    My husband asked me to help a friend out and show him the "polishing ropes".
    Only issue I have is he just bought a PC and I've never used one. I'm a Flex and Rupes girl.
    Anything I should know before I hand out technique, advice, etc to this guy?
    Thx.
    2022 Jeep Gladiator Rubicon • 2021 Ford Ranger Lariat •2016 Alfa Romeo 4C Spider • 2006 Buell Lightning-Bolt • 2004 Jeep Wrangler Rubicon
    Apr 2012
    7,494
    Re: Any advice for someone starting out on one of these?
    2019 Nissan Rogue SL
    Super Member LSNAutoDetailing's Avatar
    Jun 2014
    Chandler, AZ
    3,359
    Hi Monica,
    Mike Phillips has a great video on using the PC7424xp. https://www.youtube.com/watch?v=Et6Egpw-f-s
    The only thing you'll have to deal with coming from Flex and Rupes is knowing to use 15lbs of downward pressure while polish and IIRC the throw is 4mm.
    But it's a very easy tool to work... don't use the side handle as Mike demonstrates, even pressure has to come from the top.. plus it could be easy to have the polisher turn on an angle and the handle goes into the paint. And always use the spacer washers between the backing plate and drive.
    You should do fine... Good luck teaching your friend!
    Jul 2013
    PA
    5,026
    Thx guys! I will take a look at these before the weekend
    Super Member WaxMaster1's Avatar
    Jul 2015
    Central Florida
    1,261
    Quote Originally Posted by LSNAutoDetailing View Post
    Hi Monica,
    8mm
    In time out
    May 2016
    745
    With a PC I kept it simple. Megs microfiber cutting disks if I needed to compound. And Lake Country thin pro white polishing foam pads with m205 for polishing. 5"
    Super Member WillSports3's Avatar
    Jun 2016
    Toronto, ON
    1,453
    Maybe let him use your rupes so he'll go out and buy one. His back and his shoulders will thank you later.
    Super Member rlmccarty2000's Avatar
    Dec 2013
    Fitzgerald, GA
    2,002
    I would also suggest Meguires microfiber pads and D300 to remove scratches and swirls with the PC.
  1. Novice Starting Over - Need advice on two different cars
    By rancid in forum Ask your detailing questions!
    Last Post: 05-18-2020, 07:51 PM
  2. Starting out simple for now, advice please
    By buzz123 in forum How to make money detailing cars
    Last Post: 04-20-2014, 02:08 PM
  3. Need advice starting my business (LLC,DBA)
    By Lakeside Detail in forum How to make money detailing cars
    Last Post: 02-26-2014, 02:40 PM
  4. Just starting out and need advice!
    By Matt@FourAcesMD in forum How to make money detailing cars
    Last Post: 02-26-2014, 01:26 AM
  5. Pad advice for someone just starting out.
    By mdchaser in forum Flex Polishers
    Last Post: 07-03-2013, 06:43 PM
» March 2024
2526272829 1 2
3 4 5 6 7 8 9
10 11 12 13 14 15 16
17 18 19 20 21 22 23
24 25 26 27 28 29 30
31 123456
