Results 1 to 9 of 9
    Aug 2007
    porter cable noise?
    hi guys, newbie here.... i just purchased a porter cable 7424 unit and i was wondering if it suppose to make metal to metal, screeching type noise as it runs? sounds like something is wrong but im thinking im hearing the counterweight or something. ive heard rotary units before and they sound really smooth, does a DA orbital suppose to sound like this?
    thanks
    Steve
    Super Member Rsurfer's Avatar
    Jan 2007
    14,094
    Re: porter cable noise?
    Quote Originally Posted by ghostrank View Post
    thanks
    Steve
    It is a little noisy, sounds like something is loose in the unit, but this is normal. Check and make sure nothing is loose or rubbing on the counter weight.
    Jun 2007
    453
    gary26
    Make sure your using the spacer washer when you attach your velcro pad to avoid metal to metal contact.
    Dec 2007
    Mayaguez P.R.
    Iam new using it too, I use ear plugs because off the noise is annoying after a while using it
    Super Member Fly bye's Avatar
    Nov 2007
    789
    Re: gary26
    Quote Originally Posted by gary26 View Post
    Without the washer, the wrench won't fit in between the backing plate and the machine.
    Super Member ScottB's Avatar
    Mar 2006
    South Florida
    18,803
    Re: gary26
    remember the washer ...its usually the culprit .
    Jan 2007
    1,153
    Re: gary26
    Quote Originally Posted by killrwheels@autogeek View Post
    I have two PCs that are quite old, one over ten years the other about seven. Neither of these units came with the washer you speak of and I can't saythere has been any problem getting the wrench behind the BP. Was the use of a washer something relatively new?
    Super Member lethalxls1's Avatar
    Oct 2007
    FLORIDA
    544
    I have no washer on mine either and it works fine.
    98 Z/28
    Super Member MikeyC's Avatar
    Mar 2006
    Massachusetts
    885
    Quote Originally Posted by lethalxls1 View Post
    I have no idea what this washer is that people are referring to. I have no washer and my PC (until I traded it in for a Flex) worked fine without it and I had no problem getting the wrench in there to change the backing plate.
    You like Nattys, I like Souveran, and Justin is DP MaxWax. And you know what, its alright !!
    -Killrwheels
  1. Troubleshoot: Porter Cable 7336 noise / surge (w/video)
    By ba7 in forum Porter Cable 7424XP Dual Action Orbital Polisher
    Last Post: 06-03-2015, 11:51 AM
  2. Porter Cable + Meg's UC... Now What?
    By eff in forum Auto Detailing 101
    Last Post: 08-29-2013, 04:16 PM
  3. porter cable xp
    By Bamafire in forum Product Reviews
    Last Post: 11-05-2012, 08:11 AM
  4. Porter Cable noise and Pad remedy question
    By Infinite1 in forum Porter Cable 7424XP Dual Action Orbital Polisher
    Last Post: 01-21-2009, 12:29 AM
  5. Porter Cable & BMW
    By marchese_alexander in forum Auto Detailing 101
    Last Post: 06-14-2008, 03:47 PM
