Results 1 to 4 of 4
    May 2017
    7424 classic with hex adapter?
    I have an older PC7424 non-XP that I bought from Autogeek years ago. At the time, they had a system using a hex adapter for the foam pads with a pushbutton release in the center of it. The pads all had a hex cutout in the center and clicked into place.
    Are pads for this system still available? If not, maybe a recommendation for pad for light polishing, 3M synthetic sealant application and removal?
    Thanks,
    -radiotron
    '16 Carbon Steel GTI
    Junior Member Photomask's Avatar
    Dec 2016
    Deepinahearta, TX
    38
    Re: 7424 classic with hex adapter?
    Send a pic to be sure but it sounds like the 3M adapter for using rotary foam pads. Double sided can just flip the pad over and keep polishing. Never heard of one being used on a DA.
    May 2017
    Sounds about right. The discs are double sided. Here's a pic.7424 classic with hex adapter?-20170527_130115-jpg
    Super Member VISITOR's Avatar
    May 2007
    9,728
    The Edge 2000 Quick-Connect Adapter for the Porter Cable 7424
    ^ they stop selling the adapter and pads years ago. pick up a 5" DA backing plate (GG 5" DA vented) and some thin pads (LC thinpro/GG BOSS) and you'll be good to go...
  1. Need Adapter?
    By Midnite8 in forum Auto Detailing 101
    Last Post: 03-12-2017, 02:59 PM
  2. Adapter
    By precisionmobile85 in forum Rotary Buffers
    Last Post: 06-30-2016, 06:36 AM
  3. Replies: 6
    Last Post: 04-08-2016, 03:25 PM
  4. Anyone have a problem with grease/oil coming out of the PC 7424 or Edge Adapter ?
    By cullen2505 in forum Porter Cable 7424XP Dual Action Orbital Polisher
    Last Post: 07-09-2012, 11:34 AM
  5. Replies: 0
    Last Post: 12-22-2009, 04:59 PM
