Page 1 of 3 123 LastLast
Results 1 to 10 of 24
    Super Member Paul A.'s Avatar
    Dec 2007
    Tampa Florida
    5,274
    7336 Question. cover removal...
    For the life of me I can't figure out how to remove the black plastic gear head cover from my old PC 7336. It's always been a loose fitting cover (by design i believe) but I want to get inside there and clean and grease everything up. Can anyone tell me the magic trick?
    Super Member dlc95's Avatar
    May 2013
    Rochester Hills, Mi
    6,016
    Re: 7336 Question. cover removal...
    I'd like to know too!
    For the life of me, I can't get it off.
    Dec 2014
    Boonsboro, Md
    2,724
    Looked around just a little and found a site that had a slight amount of info.
    Here was a response to a customer that had asked the same question.
    "Hello rwhitaker1,
    There are no screws holding the 699946 gear housing cover on. You have to work at by prying it off and it is not an easy job. Sometimes it ends up breaking. But as far as I know that's the only way to remove it. Maybe one of our forum members will read this and have a better way to do it."
    Just seems to be pressure fit. It be nice if they told you which direction it comes off, but I would assume it would move it forward.
    ____________
    Dec 2007
    Tampa Florida
    5,274
    Thanks Mantilgh. That is what it seems like now that you mention it... a pressure fit cover that just may take some persuadin'! I just hope it goes back on easily.
    If I figure it out, dlc, i'll let you know what worked.
    Thanks guys.
    May 2013
    Rochester Hills, Mi
    6,016
    Thanks guys!
    I'm nervous to hulk out on it... I don't want to break it.
    Dec 2007
    Tampa Florida
    5,274
    Yeah, me too. I got fairly aggressive with it earlier today but then was afraid I might break it so I figured i'd ask here.
    Junior Member Photomask's Avatar
    Dec 2016
    Deepinahearta, TX
    38
    The plastic cover snaps onto the metal gear housing. Use a large punch or block of wood and drive it off with light hammer strokes, towards the front. I have 2 of them and have removed the covers before.
    May 2013
    Rochester Hills, Mi
    6,016
    Quote Originally Posted by Photomask View Post
    From the top of the unit?
    Dec 2016
    Deepinahearta, TX
    38
    I usually drive one side behind the handle mount hole until it moves a bit and then hit the other side and it pops off.
  10. #10
    Dec 2016
    Deepinahearta, TX
    38
    To put it back on, just set it in place and snap it on with judicious application of the pimp hand. Got to keep your pimp hand strong.
  1. Car cover question
    By Kingofdust in forum Ask your detailing questions!
    Last Post: 09-23-2014, 07:15 AM
  2. Question on PC 7336
    By rdfkentucky in forum Porter Cable 7424XP Dual Action Orbital Polisher
    Last Post: 07-21-2012, 07:29 AM
  3. Wild Paint Job - Swirl Removal - Cover of Trukin Magazine
    By Mike Phillips in forum Off-Topic
    Last Post: 09-13-2010, 09:16 AM
  4. Car cover Question
    By Bimmerfan in forum Auto Detailing 101
    Last Post: 10-09-2009, 07:31 PM
  5. Car Cover Question
    By SRHTX in forum Auto Detailing 101
    Last Post: 08-04-2009, 05:19 PM
