» Detailing Classes
Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
    Senior Member dlc95's Avatar
    May 2013
    Rochester Hills, Mi
    5,212
    Re: Counterweight question when running 3" pads
    For 3" and 4" pad / plates I use a tool set up with a 5" counterweight.
    For 5", and 6" pad / plates, I use the tool set up with the 6" counterweight.
    Aug 2010
    New Jersey
    14,340
    Did that make any difference? 15 years ago counterweight discussions were all the rage, but I think ulitmately, as FunX said, it was pretty much a moot point for polishing, because any velcro plate/polishing pad combo was so much heavier than a smooth plate/piece of sandpaper.
  3. #13
    May 2013
    Rochester Hills, Mi
    5,212
    Yes.
    Noticeable reduction in vibration in 3/3.5" with the 5" weight, and greater power, and reduced vibration with 5" plate.
    They would need a heavier weight to offset the 6" pad set up when fitted with a 6.5" pad.
    Everything steps up a level when a pad is on the plate over a piece of paper.
    I've run a 6" weight in my PC since day one. Once I got one with a 5" weight, I could see what everyone was talking about regarding the lack of power with the PC. That inertia with the heavier weight definitely helps things out - not incredibly drastically, but noticeable.
  4. #14
    Aug 2010
    New Jersey
    14,340
    I'm not sure I'm following you...I changed the counterweights on any PC's I had that had the 5" to the 6"...but you're saying you get better performance on the smaller (3") pads with the 5" weight? I never changed any of mine back for use with smaller pads, I usually have one set up for 4" that still has the 6" weight in it.
  5. #15
    May 2013
    Rochester Hills, Mi
    5,212
    Yes.
    I get less vibration using the 5" weight with the 3, and 3.5" plates.
    Like you I have one set up for 4" pads, and one for 5.5".
  6. #16
    Jun 2009
    Stuart, Florida
    45,489
    Here's a question....
    Besides the Porter Cable in all it's variations - is there ANY other simple 8mm free spinning DA that offers the option to change to a different counterweight? Does any of the other makers of all the copies of the Porter Cable even make a different counterweight?
    Or is Porter Cable the ONLY company that offers a choice in counterweights?
    Maybe someone can do some searching?
    Me? I have 2019 Plastic Fantastic to buff out today...
    Mike Phillips Facebook Page
    Twitter
    Instagram
    Mike Phillips Detail Training Credentials
  1. Smaller pads, ditch the counterweight?
    By 05RLS2 in forum Porter Cable 7424XP Dual Action Orbital Polisher
    Last Post: 07-26-2011, 11:29 PM
  2. 6" counterweight on 5.5" pads
    By c5z06camaro in forum Porter Cable 7424XP Dual Action Orbital Polisher
    Last Post: 03-05-2011, 04:45 PM
  3. 5" counterweight
    By IOMCAMARO in forum Auto Detailing 101
    Last Post: 11-21-2010, 10:21 PM
  4. Installing 6" Counterweight?
    By e24mpwr in forum Porter Cable 7424XP Dual Action Orbital Polisher
    Last Post: 05-30-2010, 09:04 PM
  5. Using counterweight with PC and Edge Pads
    By darksparkz in forum Porter Cable 7424XP Dual Action Orbital Polisher
    Last Post: 03-10-2007, 02:08 AM
Members who have read this thread: 6
» March 2020
1 2 3 4 5 6 7
8 9 10 11 12 13 14
15 16 17 18 19 20 21
22 23 24 25 26 27 28
29 30 31 1234
