Quote Originally Posted by joleyred View Post
It was really about 1 month, maybe a little longer. I will likely do as you suggest. Repolish and recoat with Synergy. It does really make the black look great.
Do you really need to polish (remove clear coat) for the water spotting or would a water spot remover (chemical) work? If you keep polishing because of water spots you may not have any clear coat. To my knowledge there is no sealant/wax/coating that will prevent water spotting, especially in acid or hard water conditions.
