Results 1 to 6 of 6
    Junior Member Deebo1133's Avatar
    Mar 2014
    57
    PBL wheel coating safe wheel cleaners?
    I know that they claim you will only need soap and water to wash off brake dust after coating but I am concerned w/Runnoff from whatever tire cleaner I use, wheelwells etc. I am planning on using OPC and was hoping I wouldn't have to worry too much about the wheel coating as I am cleaning around them.
    Super Member Eric@CherryOnTop's Avatar
    Jun 2012
    Fishkill, NY
    1,168
    Coatings will only come off with abrasion, you can use whatever you like on them.
    Cherry on Top Auto Detailing, Fishkill NY
    https://www.facebook.com/CherryOnTopDetailing
    Super Member swanicyouth's Avatar
    Mar 2011
    Limerick, PA
    9,388
    Strong acids and alkaline products can degrade some coatings. So, something like Wheel Bright or a high pH wheel cleaner may not be good for you. I'm not sure how iron dissolving wheel cleaners will affect the coating. But, a surfactant based wheel cleaner / APC should be OK once properly diluted.
    Mar 2014
    57
    Re: PBL wheel coating safe wheel cleaners?
    Thanks for the help Gentleman. I am using OPC at 3:1 so should be ok.
    Junior Member richzak's Avatar
    Jan 2014
    New Mexico
    35
    I recently bought a new set of wheels and since I had the Pinnacle Black Diamond Wheel Coating, I coated the wheels before they were even mounted w/ tires.
    So far the coating has held up, and seems to keep the wheels fairly clean. Easy to wash. Time will tell how it holds up, but satisifed so far. Wheels clean well with just standard hose pressure and a microfiber sponge with Meguiars car shampoo.
    Nov 2012
    67
    My wheels are coated with PBL wheel coating. Ive been using Sonax FE to clean the wheels. Will that destroy the coating?
  1. pH Neutral Wheel Cleaners as Tire Cleaners?
    By Setec Astronomy in forum Auto Detailing 101
    Last Post: 05-14-2014, 08:06 AM
  2. Opinions on wheel safe tire cleaners?
    By davisontech in forum Auto Detailing 101
    Last Post: 03-07-2012, 07:45 PM
  3. Safe wheel cleaners?
    By pcw25 in forum Auto Detailing 101
    Last Post: 11-26-2011, 09:12 PM
  4. Meg's All wheel cleaner safe for this wheel?
    By Mister B in forum Auto Detailing 101
    Last Post: 11-02-2010, 09:41 PM
