Results 1 to 5 of 5
    Newbie Member Ebf2k's Avatar
    Jan 2013
    PBL Coating safe to use on Krylon UV Spray clear?
    I have a couple of projects that I use Krylon UV clear on, then wet-sand/polish.
    Is it safe to use my PBL Coating on top for some added protection?
    Here's the MSDS if that helps http://www.paintdocs.com/webmsds/web...C=724504013051
    Jan 2013
    Re: PBL Coating safe to use on Krylon UV Spray clear?
    I did a test on a smaller piece that I did last month so the paint should have been fully cured by now. The PBL Surface Cleansing Polish stripped it right off, LOL. I'll have to respray!
    Super Member The Guz's Avatar
    Jun 2013
    LA, CA
    8,719
    Hmm that's no good. I wonder if the duplicolor clear from the perfect paint match would work better with PBL.
    I just painted a set of center caps that I then wet sanded and followed up with M105/M205. The clear was still intact. Not sure if it's worth anything but that's my experience.
    Jan 2013
    Does the Duplicolor have the UV protection like the Krylon? That's critical for the epoxy resin I'm using on these projects.
    Jun 2013
    LA, CA
    8,719
    I believe it does. I will have to check the can to double check.
  1. Safe to reuse spray bottles?
    By S4Dallas in forum Auto Detailing 101
    Last Post: 06-28-2015, 06:00 PM
  2. Replies: 13
    Last Post: 01-26-2015, 09:53 AM
  3. clear coat and paint safe adhesives?
    By Texarkana in forum Auto Detailing 101
    Last Post: 10-25-2014, 12:49 PM
  4. Pinnacle Clear Coat Safe Wheel Cleaner
    By SYMAWD in forum Product Reviews
    Last Post: 04-21-2014, 07:45 PM
  5. Is it safe to steam clean clear coated wheels ?
    By Webb in forum Auto Detailing 101
    Last Post: 04-05-2012, 08:36 AM
