That's the truth about premium. They have been marketed as being "better" for your car and so many people buy into it. If you don't have high compression and/or advanced timing, premium is actually worse for your car, as you stated. If the motor requires it, it will be stated on the gauge and/or filler door.
Originally Posted by dontsleeponit
Do Tell More! Mobile 1 is the factory oil for the 05-06 GTO, but from what I can tell it runs a standard PF52 Delco filter...
GM makes a standard filter for all Vettes up until mid 06, it was PF44. The synthetic version is UPF-44 and special order. I am not sure it they make one for the GTO. Its in a gold/blue/red/white box versus standard blue/red/white box from Delco.
awesome.. ty killr I will look into it!
Just want to be sure I have this straight
My daily driver is nothing fancy. A normal 6 cylinder motor. Manual says it will run on 87. I use Lucas fuel additive usually with an ocassional BG cleaning. So, if I buy into what the Shell gas station owner says and run high Octane, not only would it be a waste of money, but may actually tend to deposit energy robbing deposits as well? Just checking. If I got that straight I will pass the word on to some friends as well.
63 bucks shipped for 4 BG44!!!!!
Originally Posted by FMINUS
been using Costco, Shell, Mobile, 76, Citgo.
It all averages out to be the same via on board computer.
TSX 27
M3 21
S2000 24
You get 21 on your M3??????????????!!!!!!!!!!!!!!?????!!!!!!!!!!????? ??? My OBC says I get 16.1 on my 325CI, I do pwn my pedal though. Im not sure how you drive. I ride with my foot on the floor, i guess that has to be it? But still......21 mpg???? Thats odd. Whats your secret?
Originally Posted by wytstang
If you want a cheap way to clean out the combustion chamber just fill up and take the car WOT on a empty highway or back roads with no cops for just a couple of minutes.
I guess my cumbustion chamber must be very very clean then........... When I get pulled over im going to use that one COP:
" son, why were you going 60 in a 25?" ME: "I was just cleaning out my cumbustion chamber officer..."
LOL good luck and post your results .
Ding Ding Ding we have a winner, like mentioned unless you have a high compresson motor or advace timing you don't need it and can't burn it (assuming you have a stock ingnition and not an aftermarket multi spark system [MSD,Mallory,ect,ect]). If you have been using it (premuim) for a bit you will probably go though your first tank (83 octane) quickly. Gotta give your computer a chance to readjust.
Premium fuel is only better for your vehicle when it is required. Premium actually burns slower in the combustion chamber. On a normal (low compression or unaggressive timing) engine, this actually results in an incomplete burn cycle. The purpose of premium is to slow down the flame propagation and prevent preignition in high comp. or advanced timing engines to prevent detonation. That is the reason for higher octane (race fuels), to allow more compression and more timing to extract more power from the engine without damage from preignition. MM&FF magazine did a test a while back between 87 & 93 octane fuel in a stock Mustang. The 87 octane made more power on the dyno than the 93 octane. You want a quick combustion process to exert the most force possible down on the piston to make power. If the process is slow or incomplete, it will not exert as much downward force as it could, therefore resulting in less power. The reason for the premium, is the higher compression engine wants to burn the fuel too quickly, and/or the advanced timing wants to burn the fuel too quickly before the piston is at TDC (top dead center) which will cause detonation.
Hope this clears it up instead of confusing you more!
Are the imported engines usually high comp...say the honda v6 vtec's? Seafoam and lucas in the same tank or seafoam first then lucas. What about BG13?
By Krohnj94 in forum Auto Detailing 101
Last Post: 03-03-2017, 09:50 PM
By Ballistic in forum Auto Detailing Tools and Accessories
Last Post: 10-21-2015, 09:20 PM
By Bill1234 in forum Off-Topic
Last Post: 07-22-2015, 08:05 AM
By George Brown in forum Off-Topic
Last Post: 06-30-2014, 08:57 AM
