Project cammed GTO is alive! pics/video
Started working on it Tuesday after work. I got the tear down completed, which consisted of removing the following: Intake tube, Radiator, electric fans, crank pulley, water pump, timing cover, coil packs, valve covers, rocker arms, pushrods, spark plugs and wires.
Here is a untuned video of it running.
BTR Stg 3 NA cam. Untuned - YouTube
Below are a few pics of me changing out the valve springs. I used a fitting screwed into the spark plug hole with a hose attached to my air compressor to keep the valves from falling while changing out the springs/seals/retainers.
Below is the proform dual spring compressor for LS series engines. Worked like a charm.
The springs were being replaced with dual coil titanium valve springs and titanium retainers from Brian Tooley Racing. Also replaced the valve seals while I was there.
I also installed a new C5R timing chain from Katech and a new oil pump along with a 160 deg thermostat. I didn't get and pics of the cam swap but here is the engine all back together. The car is untuned right now and will be hitting the dyno and tuner this saturday for dialing in and horsepower results. Before #s 385rwhp 387rwtq. Shoot for 425-430rwhp.
Re: Project cammed GTO is alive! pics/video
Thank you.
No valve adjustment needed on these motors. Just bolt the factory rockers on and tq to 22ft lbs and call it a day. As long as your pushrod length is correct then you will have the right amount of preload on the lifters. Usually around .050-.070 preload. Typically you get a little more valvetrain noise on these engines with aftermarket springs pushrods and a cam. Even the headers make them sound like a sewing machine sometimes. LOL
Hope you record the dyno pulls/tuning, I'm subscribed!
2022 Elantra N Cyber Gray
Absolutely I will be videoing the dyno pulls. Maybe get a go pro vid in car afterwards of some fun time!
Music to my ears! Sounds great!!!! Can't wait to see your #'s! Keep us posted...
Scott Harle
Autodermatology
#autodermatology
Couldn't agree more. Fortunately the stock rockers on these ls motors can take quite the beating. Comp makes a nice little roller trunion upgrade to replace the needle bearings inside the factory rocker on these engines.
http://www.summitracing.com/parts/cca-13702-kit
My buddy Terry actually has a set of the upgraded factory ones that he no longer needs due to upgrading his LS to a shaft mount rocker setup from Yella Terra. He said he will let me have them since there just sitting around.
By Mike Phillips in forum Wednesday Night Detailing Classes - Info & Dates
Last Post: 05-23-2019, 09:53 PM
By Jean-Claude in forum Show N' Shine
Last Post: 06-12-2018, 09:20 PM
By Jean-Claude in forum Auto Detailing 101
Last Post: 10-21-2016, 09:25 AM
Last Post: 01-31-2014, 05:23 PM
By Mongoose in forum Show N' Shine
Last Post: 03-14-2011, 07:14 AM
