Results 1 to 8 of 8
    Super Member tuscarora dave's Avatar
    Aug 2009
    Etters PA
    5,403
    Any antique bicycle enthusiasts here? Need some help.
    I am working on restoring this old three wheeled Royal Enfield tricycle. I need to find a source for parts for this thing. Mostly everything can be either painted or re-chromed, but when I removed the rear wheels and rear frame section I realized that one of the wheel bearings is completely gone. Both the balls and the bearing cage are completely gone on the inside of the non driven wheel hub.
    Anyone here deal in old bicycles or know of any sites to find old hard to get parts for them? I started a google search and am far from done searching but thought I would appeal to the membership here for ideas. I'll probably go to a bicycle shop with the wheel and the cone type bearing race and see if it's a common size bearing.
    Super Member swanicyouth's Avatar
    Mar 2011
    Limerick, PA
    9,388
    I don't think I can help you, but I love old BMX Freestyle Bikes from the 1980s
    True works of art
    Aug 2009
    Etters PA
    5,403
    Re: Any antique bicycle enthusiasts here? Need some help.
    Quote Originally Posted by swanicyouth View Post
    True works of art
    Yeah me too!! That kind of reminds me of the SE Racing Quadangle I had back then.
    Jun 2011
    2,711
    Try searching at/for Bearings Incorporated.
    Bill
    Aug 2010
    Fairmont, MN
    3,189
    I do believe that most if not all British bikes had loose bearings, hence no cage.
    Bill
    Super Member cleanmycorolla's Avatar
    Apr 2012
    Pasadena, CA
    3,805
    I know nothing but figured since I am sititng on my but and maybe find a good reference site for you, seems like this might help! Price are in Euro
    The Tricycle Association - Home
    Back to the full-time grind.
    Super Member pixelmonkey's Avatar
    Sep 2010
    Oklahoma
    533
    I did something bad almost a decade ago in college...
    we found a 3 wheeled bike like this in a scrap yard and stole the rear, wheels and a few other things to use on a 4 wheel, side-by-side bike for a parade.
    Had the same problem with the outer bearings in the housing being shot. Was fortunate to find the local bearing distributor had the FAG brand bearing we needed in stock! cost was around $9 each.
    after the parade, we chopped the frame for a few other projects and I believe I still have the hub, rear and a few other parts in the attic. Might be the same setup as what you have photo. The rear hub has a gear reduction system inside that is controlled by an arm.
    let me know the outer size of the axle and the inner diameter of the housing.
    chris<pixelmonkey>
    Aug 2009
    Etters PA
    5,403
    Quote Originally Posted by BillE View Post
    Bill
    Hi Bill, This tricycle did indeed have caged ball bearings which is what concerned me. I did get this situation figured out by taking the wheel and the bearing cone races into a local bike shop. They suggested that it would be better to have loose ball bearings in it than caged bearings. They sold me a handful of loose ball bearings. Problem rectified. Thanks for the replies though guys!!
  1. Carbon Fiber BICYCLE
    By Bostonbull in forum Auto Detailing 101
    Last Post: 08-14-2017, 11:37 AM
  2. Detailing a bicycle?
    By cleanmycorolla in forum Auto Detailing 101
    Last Post: 08-06-2012, 12:46 AM
  3. Bicycle Protection?
    By jbone in forum Off-Topic
    Last Post: 05-03-2012, 03:53 AM
  4. In Need of Bicycle Advice
    By Deep Gloss Auto Salon in forum Off-Topic
    Last Post: 03-09-2012, 09:20 PM
  5. bicycle applications
    By Torsion Tool in forum Auto Detailing 101
    Last Post: 07-12-2006, 09:06 PM
