A guestion on avatar's
I have been reading to find the answer but to no avail. I would like to select my avatar using option #2 but that option won't highlite. Iam usually pretty good with computers but Iam stumped. Seems like everyone else has figured it out
Re: A guestion on avatar's
Find the avatar you like then copy and paste into box
If you're referring to uploading a profile pic i've been having te sane issue. Whenever I hit the "save changes" button I get "Upload of file failed.". I've tied using both a .png and a .jpg and they were both under the 150pixel and 34.2KB size limits. I'm uploading straight from my computer, not a URL, and it puts it there in my profile where i can see it, but it fails uploading and then doesn't display.
Is this what you are also experiencing?
I can't believe I'm offering IT advice
Sounds like it's the size if you can see it when you attach it but it fails when you submit it. Make sure it's the correct size, right click the file and check the size in the properties. Mine is 150x100 I set it in Photoshop before uploading. Let me know if you want me to check it?
WTG Flash be sure to add it to your resumé
In order for us to help you, your cooperation is needed
To use your own picture you MUST compress it to a smaller size.
The maximum size of your custom image is 150 by 150 pixels or 34.2 KB (whichever is smaller).
My picture is 108x108 pixels. I've tried it in 3 different formats (png, bmp and jpeg) all of which i made sure were less than 34.2KB
Try a .jpg format. And make sure the pic is under 30kb.
By Ray@Autogeek in forum Tips, Techniques and How-to Articles for Interacting on Discussion Forums
Last Post: 08-31-2020, 10:23 AM
By tenblade2001 in forum Off-Topic
Last Post: 07-13-2015, 09:00 AM
By hoyt66 in forum Pinnacle Wax
Last Post: 06-05-2011, 02:55 PM
By kellyinkc in forum Off-Topic
Last Post: 06-20-2006, 07:22 AM
