Page 1 of 2 12 LastLast
Results 1 to 10 of 14
    Sep 2011
    Tampa, FL
    104
    How do I fix this rust spot?
    This small rust spot is on the edge of my Jeeps roof. It appears to only be on the surface. What's the best way to kill, remove and seal the rust spot without damaging the surrounding paint?
    Super Member C. Charles Hahn's Avatar
    Aug 2007
    Lansing, MI
    3,103
    Re: How do I fix this rust spot?
    That looks like it's bubbling up under the paint, and has already spread farther than where the "exposed" damage is. Probably needs to all be ground down to good metal, have etch primer applied, and refinishing of the panel.
    Sorry.
    Charlie
    Automotive Appearance Specialist - Serving Greater Lansing, Michigan
    http://www.cchautoappearance.com/
    Sep 2011
    Tampa, FL
    104
    Bummer. The pictures do make it look worse than it is. I should have taken them in the sun. It almost looks like I could scrape it off.
    I want to sell this vehicle. So I'm trying to get it in the best condish possible.
    Super Member BobbyG's Avatar
    Dec 2009
    Southeast, MA
    13,211
    Quote Originally Posted by muscle View Post
    At this stage I'm sure you can scrape off some of the loose debris but what it sounds like your after is a quality job so you can see the car. Charlie's given the best advise, take it to a shop and have them do it..
    Sep 2011
    Tampa, FL
    104
    Yea, I agree. Hopefully my post didn't sound like I didn't.
    Dec 2009
    Southeast, MA
    13,211
    Not at all, you like everyone else is looking for the least expensive way to fix something but want it done correctly...
    Aug 2011
    199
    Is there something wrong with Chrysler's paint in recent years?
    In the past week alone, I have seen 3 Chrysler products with random areas of bubbling paint. They all appear to be in good shape otherwise, just some random spots where paint
    has bubbles and/or rust. The cars are: 2008 Jeep Wrangler, 2007 Dodge Grand Caravan, and 2007 Chrysler Sebring.
    Aug 2007
    Lansing, MI
    3,103
    I don't think the problem is with the paint itself, it's with the metal prep process. I've seen a lot of issues with EDP/ELPO primers not adequately covering all areas of steel panels, as well as aluminum panels with ferrous contamination leading to oxidation and corrosion in OE situations.
    Of course the fact that many OEs are also going with waterborne base/clear doesn't help either, since those finishes are more porous than the more VOC-laden solvent BC/CC systems we've been used to for the past two decades or so.
    Charlie
    Sep 2011
    Tampa, FL
    104
    The paint on my Jeep is great. It's a 2001 model. Only this one spot has a problem. It's an area of about .75" or so wide.
  10. #10
    Something that small isn't going to be a deal breaker.
    Carefully apply some matching touch-up paint after first cleaning the area and stick to your asking price.
    If I were interested in your Jeep, a little spot with touch-up paint wouldn't stop me from following through with the purchase.
    KISS - Keep it Simple Simon
    The body shop repair will just eat into your profit.
    Jeep looks great by the way! Nice color for that body style...
  1. Rust Spot!!! Spray vs Touch Up
    By Shermer321 in forum Auto Detailing 101
    Last Post: 11-09-2018, 08:07 AM
  2. How to fix this rust spot/paint chip?
    By TheMidnightNarwhal in forum Off-Topic
    Last Post: 04-11-2018, 08:53 PM
  3. rust spot
    By MikeN in forum Wet-Sanding, Cutting & Buffing
    Last Post: 08-23-2013, 06:43 AM
  4. Rust spot over wheel well help
    By farmernick in forum Auto Detailing 101
    Last Post: 08-20-2013, 03:37 PM
  5. Little rust spot on corner of hood
    By mcpp66 in forum Ask your detailing questions!
    Last Post: 03-22-2011, 10:57 AM
