Results 1 to 10 of 10
    Regular Member seabiscut88's Avatar
    Nov 2020
    Kansas City
    172
    Need help? Soldering?
    Connection for my auto lock/unlock on my topper got knocked loose yesterday and came unattached.
    I think I can solder it as I hold it to make the connection and the key fob will still activate the lock until the connection is lost.
    Any type of solder or should watch for as I try and resolder it this weekend?
  2. Likes dgage liked this post
  3. #2
    Junior Member bbmach's Avatar
    Dec 2021
    ATL
    96
    Re: Need help? Soldering?
    Should be easy enough. Make sure you get both sides clean and then use a rosin core solder, with or without lead.
    1969 460 Mach-1 / 1973 GS Stage-1 / 2000 Lexus GS400 / 2004 V-Rod / 2018 Outback 3.6R
  4. Likes dgage, Azure, seabiscut88 liked this post
  5. #3
    Nov 2020
    Kansas City
    172
    Thank you. Haven’t soldered anything since 8th grade technology class about 20 years ago.
    Bought a cheap kit online that should be here with everything for $16 and going to try and knock it out this weekend with the help from my dad.
  6. #4
    Super Member Bosko's Avatar
    Oct 2021
    Michigan
    1,584
    one of these will make your life really easy....they are dirt cheap on the long river place
  7. Thanks seabiscut88 thanked for this post
    Likes PaulMys, seabiscut88 liked this post
  8. #5
    Super Member PaulMys's Avatar
    Jan 2014
    Eastern L.I. NY
    10,773
    Quote Originally Posted by Bosko View Post
    ......the long river place
  9. Likes Bosko liked this post
  10. #6
    Nov 2020
    Kansas City
    172
    Luckily I have a couple already. I like to “build” model cars and use them for painting and holding smaller pieces but appreciate the advice!
  11. Likes PaulMys, Bosko liked this post
  12. #7
    Aug 2006
    Should be fairly easy as it does not look like circuit board trace came off.
    Choice of solder is dependent on what you can find.
    Lead free solder has a higher melting point that say 60/40 lead solder so it will take more heat to solder the connection. Be careful to not apply to much heat as you can lift the traces off of the circuit board. This where a solder station with changeable tips and temperature control comes in handy
    You will want to choose a smaller diameter solder like .031
  13. Thanks seabiscut88 thanked for this post
    Likes seabiscut88 liked this post
  14. #8
    Nov 2020
    Kansas City
    172
    Thank you! That’s the confidence booster I needed.
  15. #9
    Nov 2020
    Kansas City
    172
    UPDATE! Mission accomplished!!!!
    Thanks everyone for the support and suggestions.
    My old man came over to ride bikes Saturday and after the ride we knocked this out in 10-15 minutes.
    Hardest part was figuring a way to solder “upside down” with the soldered piece having to be held up was kinda tricky but it’s working just fine now!
  16. Likes bbmach, dgage liked this post
  17. #10
    Nov 2020
    Kansas City
    172
    Also…. During the process found a bolt was missing out of one of the hinges and the nut inside the frame on the camper shell had fallen out.
    We tried to rivet it in place but no bueno so ordered a riv nut inserter tool that just arrived today.
    Hoping next weekend to knock that out next.
  18. Likes dgage liked this post
