» Detailing Classes
Re: Question for our in-house woodworker peeps
 Originally Posted by oneheadlite
dgage - Thanks for sharing on your enclosure builds. Really helps drive home the strength of the glue!
You’re very welcome. Here is a video of the enclosures. We go around the sides with a couple ratchet straps and clamp the fronts to the backs with parallel clamps.
If all goes well, that shouldn't be an issue - as long as I can get the frame done before the mattress arrives, it'll hang out and cure downstairs.
Murphy's Law, got shipping notification it'll be here in 2 days.
Got a chance to sit down and get the core 6 boards cut last night, was pretty happy with the results (my 4 lengthwise boards are well less than 1/16" variance. Yes, such a simple thing to be excited about, but Hey! I don't do this often). I'll get them assembled next and measure up for my perimeter boards.
Neat video! And very nice looking piece!
...4 lengthwise boards are well less than 1/16" variance...
Whenever you can it's best to cut (or any other machining) multiples of any like components with the same set-up.
In your case of cutting 4) 2x4s to length that would go something like this (assuming you are using a miter saw)...
- Cut one end square
- Index that square end to a positive stop you have set-up for the desired length
- Make second cut to desired length*
* If you are as anal as I can be, I usually set my initial stop slightly long, then creep up to the final length.
If you follow this process each piece will be as close as possible to being identical.
Unfortunately I don't have a great setup for supporting the wood at work, so I'm working with the Miter Saw on the ground - While it'd be great to block off from the other end, my process has been as follows:
- I Executed a test cut to be able to place a tape mark 6" exactly back from the newly cut end. This allows me to mark wood at my cut length, backtrack 6" and have a rock solid place to line up my length cut. The saw I'm borrowing has the blade lights, but they're not working.
- Find necessary support setup for that board
- Mark board for length, add 6" mark.
- Cut
- Measure, rejoice.
Got the core support frame dry fit last night. Cross corner measurements are within 1/8", not sure what standard room for error is for square. I'm guessing an Amazon bed frame probably wouldn't be that close.
Hopefully getting the rest of my boards cut tonight.
Looks good!
Are those dowels in there to hold the slats?
Nice Job!
 Originally Posted by 2black1s
Looks good!
Nice Job!
Thank you!
Yeah, the dowels are just inserted dry to help keep the slats located. I went back and forth on if I wanted to locate them with dowels (my first thought), screw them in place, or use spacer blocks between the slats (suggested by a friend). I went with the dowels figuring it would be easiest for removing/reinstalling the slats. I built the frame in the basement, but waited to install the supports/legs and the slats until it was upstairs (less weight to transport! ).
How are you going to stop the mattress from sliding?
And really great job!
And if you’re looking for an easy finish, Rubio Monocoat is a hard wax that I’m starting to use.
By Aaryn NZ in forum Auto Detailing 101
Last Post: 01-21-2020, 04:43 AM
By tony58 in forum Off-Topic
Last Post: 01-23-2016, 12:19 PM
By Mike Honcho in forum Auto Detailing 101
Last Post: 08-13-2015, 04:54 AM
By Bacon in forum Off-Topic
Last Post: 10-19-2011, 06:20 PM
By guess23959 in forum Off-Topic
Last Post: 08-04-2011, 07:33 PM
Members who have read this thread: 58
- John U,
- Larry A,
- brianshaeffer,
- 99C5Coupe,
- Rsurfer,
- Alex,
- bill walsh,
- tomsteve,
- Wknd Dtlr,
- Misterpaul,
- TroyScherer,
- hansen97,
- 70fastback,
- grovlet,
- Health Guide,
- vobro,
- sixsix,
- bluehawk1,
- weekend warrior,
- JDGolden,
- Zelfiris,
- dgage,
- Kappy,
- wierdkid,
- supercrewdude,
- Jlt23,
- ducksfan,
- PaulMys,
- rmtaylor51,
- Guyb,
- 2black1s,
- talonted,
- MIsnowman,
- oneheadlite,
- Ancient1,
- Jim w,
- chadkintz,
- LEDetailing,
- smokejumper,
- SNP209,
- josnow,
- BSoares,
- Stormin08,
- kttlbll,
- mk9750,
- Gparr,
- dennis b,
- 57Rambler,
- Doug Thompson,
- stunod,
- DFB,
- Dry Bones,
- Scott71,
- Ed Abbondanzio,
- waddell64,
- Odrapnew,
- djhassey,
- dbeng
27 | 28 | 29 | 30 | 31 |
