Page 2 of 6 FirstFirst 123456 LastLast
Results 11 to 20 of 53
    Jan 2015
    Simi Valley, CA
    1,783
    Re: Question for our in-house woodworker peeps
    Quote Originally Posted by oneheadlite View Post
    ... Separate question - Do you think using the Kreg Screws 90° into the wood (I'd pre-drill for this part) would be fine for attaching the 2x4's to the outer 2x6's? Wasn't sure what the best hardware would be for that application; seems like with the smooth upper shank that would be a safe way to go.
    Yes.
    But so would just about any other wood screw.
    2 1/2 L.
  2. Thanks oneheadlite thanked for this post
  3. #12
    Aug 2015
    Andover, MN
    1,727
    Forgive the fact that it’s just a screen shot of the app I used to rough in the idea. It’s to-scale, each lil square is 1 inch.
    Center 6 boards are the 2x4’s, perimeter 4 are the 2x6’s. The squares show (roughly) where the slats go (I’ll even then out during install).
    End view at top; I’ll have to notch the 2x4’s to clear the laid-down 2x6 supports (that the legs mount to) so the whole support structure is hidden.
    Hopefully this makes sense!
  4. #13
    May 2013
    TN
    1,768
    I missed pocket hole mention in your post.
    With 2x material, are you using the Kreg HD or at least larger screws? The standard system isn’t compatible with 2x material. Also make sure you use coarse screws as the fine screws are for plywood. And the Kreg screws have a drilling tip so it shouldn’t split.
  5. Likes oneheadlite liked this post
  6. #14
    Super Member 57Rambler's Avatar
    May 2019
    Columbus, OH
    1,026
    I'm familiar with how wood needs to be sealed on all sides, any kind of finish on our deck has been a losing battle since we've moved in for that reason (plus it was timing out when we got there anyway).
    2 words ... Armstrong Clark. Most people have their deck finish fail because of using the wrong (or crappy) product. And also, as with car detailing, surface prep is critical. To get a wood deck right you need to first strip the wood of old paint/stain, then follow that up with a brightener. Only then is the wood ready for new stain. Armstrong Clark makes some of the best.
    Corner joints will be pocket screws, still debating fastening method for support structure to outer rails. Thinking simple screw straight in at 90°. Center cross support will be 2x6, corners will be 45° 2x6's to pull the legs in from the corners 6". Feet (6 total) will be 6.5" tall 4x4's with hardwood dowels inserted across the grain to ensure the hardware has something good to grab onto.
    Have you considered adding any corner braces ?
  7. Thanks oneheadlite thanked for this post
  8. #15
    May 2013
    TN
    1,768
    Based on that, you shouldn't even need to use pocket screws and you might be better off just using screws, especially with your nested construction. It would be stronger than pocket screws but definitely drill pilot holes. If you don’t want the screws to show on the outside, you could use wood pegs to cover the screws. I’d recommend drilling through the side and into the end grain and use long coarse screws
  9. Thanks oneheadlite thanked for this post
  10. #16
    Super Member PaulMys's Avatar
    Jan 2014
    Eastern L.I. NY
    10,773
    I do quite a bit of work for my cousin who is a high-end woodworker, master plumber, and GC.
    I would stay away from D-Fir for your bed frame.
    The one simple reason is that D-Fir will always warp, crown, or twist to some degree, and is highly susceptible to splitting on the end grain (with fasteners).
    D-Fir 2x4's are milled with idea that they will be supporting weight vertically (interior walls) or in the case of horizontal applications, be at least doubled up if not used for sills or other direct contact.
    And even "Kiln-Dried" can ooze fir sap in the future. Especially in a heated environment like your bedroom.
    IMO, (and to keep it "cheap") I would price out some 8/4 (eight quarter) #2 pine for your bed frame. JMO............
  11. Thanks oneheadlite thanked for this post
  12. #17
    Jan 2014
    SoCal
    1,122
    You're right Paul. But, he already bought the materials and probably doesn't want to double purchase. I would have built it out of 3/4 plywood and MDO or MDF to skirt it.
    Oh, and the PL Premium suggestion is gold. Just be careful when you use it. You won't get it off mistakes and your skin will hold it until the layer dies and peels off.
  13. Thanks oneheadlite thanked for this post
  14. #18
    May 2013
    TN
    1,768
    PL Premium 3X cleans with mineral spirits so make sure you have some on hand.
  15. Thanks oneheadlite thanked for this post
  16. #19
    Aug 2015
    Andover, MN
    1,727
    First off, many thanks to everyone, this has gotten way more responses than I thought it would!!
    Quote Originally Posted by 57Rambler View Post
    From the looks of our deck, it was probably done in by neglect. Long term house goal is tearing it down and starting over.
    As far as corner braces, the support feet at the outside corners will be 22” diagonal 2x6’s. I only made it as far as getting an example of 1 onto the draft above (bottom left corner).
    Quote Originally Posted by dgage View Post
    From my reading, I was under the impression sinking screws into end grain actually isn’t as strong due to how the fibers in the wood run? Like screwing into the end of a box of straws. Also from what I’ve read (granted, from the internet), pocket screws actually have quite a high holding capacity in all but one direction. I’m not too worried about that one weak direction as for a queen size bed constructed as above I feel like there should be plenty of material/fasteners/glue to keep it sturdy.
    Well Heck. Part of why I went with Douglas Fir was that I had read that it tended to be more stable than pine. I had even seen posts where people had made their own pine bed frame (not in the same fashion as what I drew up) and had elements of it get quite warped. But, who knows the specifics of what they were using which would have a huge effect on stability.
    Good point on how D-Fir is milled to support weight vertically; that’s part of why I have 2 center support beams. I know floor joist spacing is typically 16” on center, and mine are at 18”, but I figure since there’s no span longer than a few feet it should be ok. Especially since it’s only a queen size bed, and we’re normal size folks. And the Danes sleep on their own beds on the floor.
    Quote Originally Posted by ducksfan View Post
    Really good safety tip, thanks!
    I definitely can see the value in using manufactured lumber for strength, but a big limiting factor is that I don’t have a lot of equipment to work with. I’m borrowing a compound miter saw from a friend, and don’t have access to a table saw.
    While I’m comfortable with mechanicals (Auto tech by day, and I’m also familiar with fabrication/over-building as I’ve also been part of a series of race car builds), I haven’t done a lot of woodworking.
    What’s the working time on that glue?
    Excellent, I think I’ve got a tin of that. Thanks!
  17. #20
    Jan 2015
    Simi Valley, CA
    1,783
    Your choice of Doug Fir is perfectly fine. Sure there are other options, each with its own pro/cons, but Doug Fir is a solid choice.
    Your understanding of pocket screws vs. straight screws into end grain is spot-on.
    The PL Premium gives you plenty of working time. 30-40 minutes easy in which time you can reposition or tweak the joints if necessary. I give it a minimum of a few hours (overnight preferable) before handling or un-clamping, although that time isn't necessary in your case as the joints will be screwed.
    Suggestion... Drill all of your screw holes and completely assemble your frame before applying any glue. This is called a dry-fit and insures everything fits properly before you permanently glue anything. Then disassemble (sometimes depending on the project I'll do this one joint at a time), apply the glue, and reassemble. Another benefit to pre-drilling/pre-assembly is that joints which are glued can be difficult to keep aligned during drilling/assembly as the joint will slip and slide on the glue. Pre-drilling/pre-assembly will help you to minimize this issue.
    And finally, although you're probably already aware, be sure to restrain the frame "square" and "flat" until the glue is cured.
  18. Thanks oneheadlite thanked for this post
  1. NZ to Mickies House to Autogeek Open House to Space & Back ...
    By Aaryn NZ in forum Auto Detailing 101
    Last Post: 01-21-2020, 04:43 AM
  2. Replies: 22
    Last Post: 01-23-2016, 12:19 PM
  3. Hey Atlanta area peeps!!!
    By Mike Honcho in forum Auto Detailing 101
    Last Post: 08-13-2015, 04:54 AM
  4. Group AutoGeek PEEPS Picture?
    By Bacon in forum Off-Topic
    Last Post: 10-19-2011, 06:20 PM
  5. sry peeps i just need a vent
    By guess23959 in forum Off-Topic
    Last Post: 08-04-2011, 07:33 PM
