Results 11 to 20 of 24
    Super Member PaulMys's Avatar
    Jan 2014
    Eastern L.I. NY
    10,773
    Re: Switching to High Mileage Oil made a huge difference..
    Wierd thing is the car still goes through the same amount of oil... The correct amount to fill a 4.6 Northstar is 7.5 quarts which measures at exactly halfways on the hashmarks on the dipstick... But no matter how hard I try to keep it there it always seems to burn/drink/or otherwise dispose of that .5 quart in a short amount of time..........
    Yeah, there is the leaking (which actually looks worse than it is on concrete) and then there is the oil that slips past the rings and makes it into the combustion chamber and gets burned.
    Most people think of this as "A Lot" of oil which would cause smoke at the tailpipe, but most times this isn't the case.
    It is just enough (combined with your leaks) to use just the amount you describe, Ric.
  2. Likes Eldorado2k liked this post
  3. #12
    Feb 2012
    Palatine Illinois, USA
    24,529
    If you have a leak, it is best NOT to switch to a synthetic from what I understand. While the viscosities are the same, for some reason a synthetic oil tends to leak more.
    My wife had an old Jeep Cherokee when we first married. I switched it up from conventional to synthetic and it started to leak all over the place. I then switched back to a conventional high mileage oil and the leaks stopped. From then on, I'd only make the switch to synthetic early in the vehicle's life before the age-induced mystery leaks set in.
    Its due to the level of refinement of the synthetic oil. In the mid 90's I had an 87' GN and the rear main seals on those engine were known to leak, mine did and the engine called for 10w30 oil, I switched to 15w50 Mobil 1 and the leak went away and never came back. The thing is this, with a thicker viscosity its just that, THICKER and thus wouldn't escape through older, worn seals. I also was running about 22 psi of boost, along with supporting mods, so the heavier oil made more sense too.
    Hope this helps you next time around.
    2022 Elantra N Cyber Gray
  4. Likes PaulMys, Desertnate liked this post
  5. #13
    Super Member TTQ B4U's Avatar
    Jan 2016
    Central Ohio
    5,438
    Some people had advised me to switch to synthetic oil instead of the high mileage... After doing my own research, I’m glad I went with the High Mileage Oil.
    Synthetic advice on an old beast that's likely never been on synthetic is the opposite of what you would want to do. You my friend did well and I'm glad it's working out. Our old Jeep had a super small drip from the rear of the valve cover gasket when I picked it up but being we have a new pristine concrete drive, it was one of the first projects I tackled to keep the concrete clean. Even still, nothing but conventional oil for her and oil changes every 3k on the old girl.
    2023
  6. Likes PaulMys, Eldorado2k liked this post
  7. #14
    Nov 2015
    Los Angeles, California
    13,765
    Quote Originally Posted by IH8SPM View Post
    High mileage oil is designed to bridge the gap per say. It provides viscosity and additives that are known to rejuvenate worn and dry seals as well as minor scoring on engine parts. Consider it a good polish and sealant for our engines.
    Part of the reason I’m so surprised at the difference it made is because of my past experience using Prestone Power Steering Fluid with Stop Leak and seeing how it always made absolutely no difference when it came to stopping or even slowing down a power steering fluid leak...
    I don’t even know why they bother claiming it can help stop the leak. The stuff is garbage in that regard.
  8. #15
    Sep 2017
    Sweden
    3,022
    Did you do a completly oil change or just started to top it up?
    If you topped it or not. I would do a completly oil change with switching the oil filter. If your new oil cleaning up if it was a mess in the oil channels. The oil filter can be accumulate a lot of this old burned oil and residue. So for the safety of the engine it's a good practice to do an oil change with the change of the oil filter. Soon after going up to a higher quality oil.
    The 5w-30 is the viscosity and basicly in what environment the oil holds a good viscosity. 5w is the winter value and the 30 is the summer value.
    Then you have which size and or which the effect is in the engine. I think that you would have an API value of the oil and also a recommendation in the handbook of the car which API you should have. For an example a very little and weak engine is a SA in the API value and a stronger high volume engine around SF. It's ranges from SA-SN the API. And use what's recommended. As with a higher API value than what's recommended to use the engine can loosing it's ability to move it around cause of the weaker oil pump. I think you have API American Petroleum Institute is the shortage. Otherwise you have the ACEA value on the oils. If ACEA value it's C1-C4 with the kind of engine you have.
    The later years car manufactures has created their own classifications of motor oil. A way to use only 1 brand from them. But useally it can be translated to the API value or ACEA value.
  9. Likes Eldorado2k liked this post
  10. #16
    Nov 2015
    13,765
    I’ve just been topping it off... I know it sounds crazy but I’ve only driven the car a little over 2,000 miles since October, so while I have thought about changing the oil, it still hasn’t reached the usual time.
    But I agree with what you’re saying.. The oil cap says 5w30 but the owners manual states that 5w30 is ideal and recommended for winter and 10w30 can be used in the summertime/hotter climates. I’ve been debating whether or not to switch to 10w30 right about now but most likely I will be changing the oil soon and going with 10w30.
  11. #17
    Regular Member Black Bowtie's Avatar
    Aug 2014
    Johnston, Iowa
    106
    Just go ahead and stay with the 5w30 will be fine. Never change over to a straight synthetic on an older engine that has always used dino oil. it will free up old deposits in the engine and you will have all kinds off leaks. if you want to learn more about lubricants, check this site out. it can make your head spin.
    A Review of Mineral and Synthetic Base Oils - Bob is the Oil Guy
  12. #18
    Nov 2015
    13,765
    Quote Originally Posted by Black Bowtie View Post
    I skimmed through that page real quik... Yea that could definitely make my head spin if I were to patiently read the entire thing. Lol.
    Other than the 5w30 being fine for my car during summer, in your opinion is there any negatives in switching to 10w30 now? BTW this is the 1st time I’ve ever ran 5w30 in any of my Cadillacs and the only reason I did was because this is the 1st time it said so on the oil cap. Otherwise I’ve always used 10w30.
  13. #19
    Mar 2009
    west branch,mi
    137
    switching to a 10w 30 might even do more. 5w is pretty thin and for colder climates. switching from 5w to 10w stopped a lifter tick in my 08 grand prix.
  14. Thanks Eldorado2k thanked for this post
  15. #20
    Nov 2015
    13,765
    Quote Originally Posted by tomsteve View Post
    Hmm... I’ve got a slight lifter tick going on too. Enough for a couple of people to have mentioned it, but when I asked the dealer to have a listen he said it sounded completely normL.
    Thanks for the info.
  1. made a huge mistake today
    By rodneypierce in forum Auto Detailing 101
    Last Post: 06-09-2016, 03:20 AM
  2. Not seeing a huge difference between M105 and M205
    By mfergel in forum Auto Detailing 101
    Last Post: 09-17-2015, 11:13 AM
  3. Dealership made a huge mess >:(
    By SiliconX in forum Auto Detailing 101
    Last Post: 06-19-2014, 02:42 PM
  4. made huge mistake..help!
    By rjk2k7 in forum Hot topics & Frequently Asked Questions
    Last Post: 05-04-2014, 10:25 AM
  5. High mileage oil?
    By Glimmer Twin in forum Off-Topic
    Last Post: 06-05-2012, 11:11 AM
