Results 1 to 8 of 8
    Dec 2018
    Need Help Restoring Faded Rubber Floor Mats for Car
    Good morning all,
    I was wondering what product(s) you would recommend to restore faded rubber floor mats for a car? Below is a picture of a rubber floor mat from the drivers side of my vehicle (2016 Ford Escape). Very unsightly. Ugh!
    RG85
    Attached Thumbnails Attached Thumbnails Need Help Restoring Faded Rubber Floor Mats for Car-rubber-floor-mat-drivers-side-jpg
    Jan 2016
    462
    Re: Need Help Restoring Faded Rubber Floor Mats for Car
    You have any mothers back to black on hand? That’s what I used. Don’t be bashful putting it on. Then brush it in all the corners. Wipe off all the excess and you should be good to go.
  3. Likes RocketGirl85 liked this post
  4. #3
    Dec 2018
    WOW! That is REALLY impressive. I do not have the Back to Black. However, I have the Meguiar's Ultimate Black Plastic Restorer. I have both the aerosol and the "cream" versions. Really naive here, but how do you actually apply it so that it looks as poppin' as your mats?!
  5. #4
    Jan 2016
    462
    the back to black is a clear gel cleaner. that being said I washed and cleaned the mats first anyway. then I squirted the gel onto the mat and worked it in. just as if I was cleaning it. I used a rag and a brush to get it in all the grooves and corners. after I rubbed it everywhere I used a rag to remove all the excess. I even used some compressed air to get the excess gel out of the grooves. that's it. I mean it dried off almost feeling tacky. the only time I felt a little slickness was on a rainy day and my feet were wet. I would definitely give the meg's a try. do the passenger side first and see if it comes out slick. the back to black is a cleaner and meg's is a restorer, so I'm not sure how similar they are. post a pic when you're done rocketgirl.
  6. #5
    Junior Member Pyroman's Avatar
    Dec 2018
    Solution finish should do the trick and your feet won’t slide around.
  7. #6
    Junior Member Sports Fan's Avatar
    Jan 2019
    82
    I followed Pan's advice in this video and had similar results. This process and these products worked very well on my all-weather floor mats.
  8. #7
    Nov 2015
    Los Angeles, California
    13,765
    FYI: hmardown is talking about Mothers Heavy Duty Trim Cleaner.
    Not Mothers Back to Black Trim & Plastic Restorer.
  9. #8
    Jan 2016
    462
    Correct
  1. How to Restore Faded Rubber Car Mats
    By RocketGirl85 in forum Tricks, Tips and Techniques
    Last Post: 02-18-2019, 04:28 PM
  2. cleaning rubber floor mats
    Last Post: 08-24-2014, 07:47 AM
  3. Products for rubber floor mats?
    By dougaross in forum Auto Detailing 101
    Last Post: 10-07-2010, 08:43 AM
  4. Rubber floor mats
    By WEST SIDE in forum Auto Detailing 101
    Last Post: 09-14-2010, 11:45 PM
  5. All weather rubber floor mats
    By coolmoon in forum Auto Detailing 101
    Last Post: 01-15-2008, 11:34 PM
