Page 1 of 2 12 LastLast
Results 1 to 10 of 18
    Dec 2018
    Castlegar, BC CANADA
    Safe way to get rid of unsightly touch up paint globs
    I have some unsightly globs of touch up paint that look like seagulls S..t.
    Does anyone have some remedial techniques to restore or repair the gawd
    awful look?
    Thanks in advance
    Jax TR6
    Aug 2010
    New Jersey
    15,142
    Re: Safe way to get rid of unsightly touch up paint globs
    You should be able to use the...what was that company? Before Dr. ColorChip....Langka. You should be able to use the Langka method, get an old credit card, wrap some t-shirt material around it, dampen it with lacquer thinner, and "sand" down the blob. That's presuming you have clearcoat paint, obviously if you have an old TR-6 with a lacquer paint job, using lacquer thinner is going to be a bad idea...
    YouTube
  3. Likes tuscarora dave liked this post
  4. #3
    Dec 2006
    798
    I agree with Setec in principle but I would remove the blobs completely and start over. Langka is good stuff, just don't fall for the kit, get the base remover stuff only. And as always find a test spot out of sight before you try on the hood.
  5. #4
    Super Member Oz_TCH's Avatar
    Jul 2012
    Northern Virginia
    370
    I have the similar problem on wife's car. the touch up paint glob is sitting higher than the rest of the paint.
    Can I just use a cutting compound and buff it down ?
  6. #5
    Mar 2017
    Southeastern PA
    2,480
    Mask the paint around it and then wet sand? I'm thinking that would help level it fast w/o damaging your good clear coat. Then once level or close to use a compound and polish. I haven't done this myself but I'm thinking it might work.
    Bruno Soares
  7. Thanks Oz_TCH thanked for this post
  8. #6
    Super Member rlmccarty2000's Avatar
    Dec 2013
    Fitzgerald, GA
    2,002
    Quote Originally Posted by BSoares View Post
    I was wondering about this technique myself. I guess at the worst you could dab a bit of Dr Colorchip paint on the area to coverup where the blob use to be. I’ve got a Rupes Nano and it comes with stick on sand paper dots that might work. I suppose they are meant to work to denib paint.
  9. #7
    Jun 2015
    66
    I have seen...Take a hole punch to a piece of 1500 to 3000 sandpaper make a few small pieces and then glue it to the top of a pencil with an eraser.
  10. Likes WristyManchego liked this post
  11. #8
    Super Member Bill D's Avatar
    Mar 2006
    The First Coast of FL
    2,370
    I remember that technique from years and years ago. It worked OK but I never found anything that did so perfectly.
  12. #9
    Aug 2010
    New Jersey
    15,142
    Well, at least we all agree.
  13. #10
    I'm the last person to claim someone else's idea as my own, but I posted this in 2010 - 9 years ago....
    • Take a hole punch, punch out some holes in some sandpaper.
    • Cut a pencil down to about 2-3 inches long on the erasure side.
    • Glue these onto the face of an unused pencil erasure.
    • Place the pencil in a Drill.
    • Carefully hold the drill in such a way to sand on top of a rock chip.
    The goal is to take a ragged random shaped rock chip and turn it into a perfect circle with an even impression in the paint and now sanded clean for good adhesion.
    Then apply your touch-up paint till the hole is level.
    Allow to dry for about a week or two in warm temperatures.
    Carefully sand the touch-up paint flat.
    Remove sanding marks.
  14. Thanks Oz_TCH thanked for this post
    Likes tuscarora dave, Guyb liked this post
  1. Rotary polishing - globs flying out and drying
    By bochnak in forum Auto Detailing 101
    Last Post: 10-22-2013, 03:11 PM
  2. removing spot gloss touch up paint to expose original paint?
    By slacknh in forum Auto Detailing 101
    Last Post: 09-16-2012, 11:37 AM
  3. Paint Correction on CRACKED Paint - Safe?
    By prostar in forum Ask your detailing questions!
    Last Post: 02-07-2012, 11:37 AM
  4. Is this safe for use on paint??
    By qaz393 in forum Ask your detailing questions!
    Last Post: 07-07-2011, 10:50 PM
  5. A question about 3 stage paint and touch up paint.
    By Silverstone in forum Auto Detailing 101
    Last Post: 08-27-2010, 06:59 PM
