Results 1 to 3 of 3
    McKee's 37 Product Support
    Jan 2011
    7,265
    New For SEMA! Wolfgang Perfekt Finish Paint Prep
    Wolfgang Perfekt Finish Paint Prep is a powerful cleaner that removes unwanted polishing oils, finger prints, fillers, and silicone oils from freshly polished surfaces. What’s the importance of removing the aforementioned contaminants before waxing, sealing, or coating your vehicle? Simply put, the cleaner the surface, the better your wax, sealant, or coating will adhere. This critical step is especially important when applying Wolfgang Uber Ceramic Coating, a resin-based surface coating that will only adhere to surfaces that have been first pre-treated with Perfekt Finish Paint Prep.
    Professional detailers have long used a 15% solution of IPA (isopropyl alcohol) to remove polishing oils before applying a paint coating. While IPA is effective in this regard, it’s detrimental to the surface you just spent hours polishing because it contains no lubrication. If you know anything about surface care enhancement, you know that using a product that creates friction leads to swirls and scratches! That’s not the case with Perfekt Finish Paint Prep. Wolfgang Perfekt Finish Paint Prep is the professional, safe alternative to IPA.
    Wolfgang Perfekt Finish Paint Prep acts more like a detail spray than a solution of IPA. First and foremost, it lubricates the surface so your towel glides across the surface. Second, it doesn’t have a potent odor like alcohol does, so you won’t be left feeling dizzy and lightheaded after using it. Third, it’s much easier to use! Simply spray Perfekt Finish Paint Prep directly onto the surface to be coated, and wipe it off using a Gold Plush Jr. Microfiber Towel. Your paint will be left squeaky clean and ready for application of Wolfgang Uber Ceramic Coating.
    Wolfgang Perfekt Finish Paint Prep 16 oz.
    Wolfgang Perfekt Finish Paint Prep 64 oz.
    Wolfgang Perfekt Finish Paint Prep 128 oz.
    Feb 2011
    Minot, ND
    12,365
    Re: New For SEMA! Wolfgang Perfekt Finish Paint Prep
    Good stuff. Nice to see a specially formulated product for use as a panel wipe prior to using the Über Ceramic Coating coating rather than just an IPA concoction.
    Nov 2009
    Pasadena, CA
    12,615
    Gotta try this.
    '03 Corvette Z06
  1. Alternatives to Wolfgang Uber Perfekt Paint Prep
    By C5Longhorn in forum Auto Detailing 101
    Last Post: 02-24-2018, 11:39 AM
  2. Perfekt Finish Paint Prep
    By galaxy in forum Wolfgang Car Care
    Last Post: 12-02-2016, 09:46 AM
  3. New use for WG Perfekt Finish Paint Prep
    By ugafiredawg in forum Tricks, Tips and Techniques
    Last Post: 01-15-2016, 08:22 PM
  4. Review - Wolfgang Perfekt Finish Paint Prep
    By Audios S6 in forum Product Reviews
    Last Post: 11-23-2015, 05:12 PM
  5. PRODUCT REVIEW: Wolfgang Uber Ceramic Coating/Perfekt finish paint prep
    By Justin at Final Inspection in forum New Car Care Products
    Last Post: 10-31-2015, 06:10 AM
