Page 8 of 10 FirstFirst 12345678910 LastLast
Results 71 to 80 of 94
  1. #71
    Super Member Rsurfer's Avatar
    Jan 2007
    14,094
    Re: Optimum Opti-Lens Headlight Coating - What YOU Should Know
    Quote Originally Posted by BillH View Post
    The lights were cleaned with Meguiars 105 followed by 205. I then used 99% IPA to clean them. The Opti-lens was applied according to the directions. I lasted about 2 months before the headlights returned to their cloudy state. I cleaned them again using the same procedure, this time I applied two coats. This lasted about about 3 months before the lens started clouding again. I applied multiple coats a third time about the end of September, 2013.
    As of today, the headlights need further work but I don't think I have enough Opti-Lens to do the job. (I purchased the 10ML kit in April, 2013). I don't think I did anything wrong in application, not experiencing any delaminatingm, they just get hazy and cloudy. I see that I should have waited a day or so between coats, but this was not on the instructions. I don't feel like spending another $75.00.
    It sounds like you did everything correctly. Could it have been the humidity when applying? Your pretty wet up in Washington State. Maybe Chris will chime in.
  2. #72
    Jul 2010
    Moxee, Washingtion State
    I'm in eastern Washington, extremely dry, 30% humidity, over 300 day pr year of sunshine. The car is garaged but when I am working does sit in the sun for 8 hours a day.
  3. #73
    May 2011
    101
    I've found that it works fine on many cars, but not very well on others. Toyota sienna and corolla are a couple that I've seen fail within a few months. I have a G35 that I need to re-do from last summer... and I will have to try a heavier uv cure "factory type" coating unfortunately.
  4. #74
    Super Member Toxix's Avatar
    Aug 2012
    Toronto, Ontario, Canada
    218
    Subscribed for more information.
  5. #75
    Jul 2010
    Quote Originally Posted by mr.fusion View Post
    Hummm, Interesting as the car in question is a GS430 Lexus. What's involved with the uv cure "factory type" coating? I would like to try applying the Opti-Lens and layering it over a couple of days, but I hesitate spending the money.
  6. #76
    Dec 2013
    South Carolina
    830
    I'll just be darned if I'm going to let my OCD w/detailing include my headlights. I use a mild polish on them 3 x a year and then use a wax/sealant on them about 2 x a year and they're fine..... And this is on a 4 y/o car and I have no issues whew!!!
  7. #77
    May 2011
    101
    Multiple layers should create a much better UV barrier, but I've not done more than two initial layers.
    By "factory coating" I'm referring to the uv curing urethane coatings. Most are available in an aerosol. Whether you spray or wipe on a coating, it yields a much thicker layer... so hopefully it gives a much greater UV barrier. I've seen it last a couple years anyway. SEM, Lightrite, Speedokote, Presta,.... bunch of brands out there. The issue with any of them is applying it. It's tricky to get it to lay down smooth, without much orange peel, etc.
    I still like OptiCoat for a lot of what I do, and there isn't anything else that can do what it can. But it seems there just isn't enough UV protection for some cars. Seems to be the ones that are softer and/or thicker plastic... very easy to sand, and sometimes have a slightly opaque look even when fully restored... they don't come back crystal clear like glass. I don't keep records on this stuff and this isn't a scientific study. It's just what I recall. I usually intend to track this stuff better, but I'm too busy and not ocd enough LOL. If headlights were my bread and butter... I would have this nailed down better by now with test samples etc.
  8. #78
    May 2011
    101
    I will add... in favor of OptiLens (I meant optilens in the previous post, not opticoat).. that it's invaluable for some jobs, for me anyway. For example, on a 2006-08 Dodge truck, the top side of the massive lights will be peeled/cracked. There is no way you will sand and restore the whole lens. Just doing the top portion can be difficult enough. So the only sane way to do them is to blend out the repair area. Only a thin wipe-on coating like OptiLens, (or similar magic "nano" coating) etc will look right. Other coatings are pretty much impossible to apply to just a portion of the lens without being noticeable. And this lens has a huge surface that generally doesn't look good with a sprayed coating, or other common wipe-on coatings.
  9. #79
    Jan 2012
    Toronto, On, Canada
    62
    These last few posts really have me worried about offering Opti-Lens as an option for retail restorations.
  10. #80
    Mar 2012
    464
    I wouldnt be too worried about it. In Canada, your UV index shouldnt be that high.
    Here in Hawaii, the UV index is crazy. My wifes headlights are working on almost a year with opti-lens and are like brand new still. Every other option I tried on her lights lasted anywhere from 30 days to 3 months at most.
    Spray on clear coating isn't a perfect option either.. it WILL take you more time to apply, you run the risk of overspray, and the clear coat can de-laminate over time making your next restore that much harder.
    Here's a headlight I did with Opti-Lens
    https://www.youtube.com/watch?v=147drKMselc
  1. Video: Optimum Polymer Technologies Opti-Lens Headlight Coating
    Last Post: 02-04-2019, 11:15 PM
  2. Marketing of Opti-Lens for Headlight Restoration
    By Always Learning in forum How to make money detailing cars
    Last Post: 12-18-2015, 11:25 PM
  3. Headlight restoration with 3M kit and Opti-lens
    By nightwind in forum Auto Detailing 101
    Last Post: 01-20-2015, 12:02 PM
  4. New Optimum Coatings (Opti-Lens, Opti-Glass) In Stock!
    Last Post: 01-28-2014, 03:23 PM
  5. Questions about Optimum Opti-Lens
    By Countersteer46 in forum Ask your detailing questions!
    Last Post: 05-15-2013, 08:23 PM
