GTechniq Scratch Resistance?
Is it true that you must use C1 to achieve any scratch resistance?
The other exterior coatings (C1.5 and Exo) do not alone offer scratch reistance. Thanks.
Re: GTechniq Scratch Resistance?
I contacted Rob at Gtechniq and he emailed that EXO provides some scratch resistance, while C1 gives the most and C1.5 none.
Yup! C1.5 is not a coating, more like a spray sealant so scratch resistance is out!
Personally for a winning combo, I'd go with opti-coat 2.0 topped with Gtechniq Exo!
Not sure about EXO over OptiCoat...I'd go C1/EXO or CQ/EXO to get good scratch resistance, or even EXO x 2. EXO is compatible with other quartz based products.
c1 has scratch resistance. exo has some but not as much and c1.5 none at all.
but for us probably the biggest factor for prevention of swirl build up is dirt repellency. if a surface requires less frequent washing and if when you do come to wash it you have to use less passes to clean the surface this means you are less likely to introduce any swirls into your finish.
Would you guys put on C1 after EXO !
I meant C1 &n after you put on EXO
Why?
Are they the same thing I mean the same purpose C1 then EXO, I ask it , if I knew I would t LOL
never c1 after exo. exo after c1 yes and advisable if your vehicle's paint is particularly prone to wash marring as c1 has superior marr resistence to exo but is fully compatible with exo.
Last Post: 12-11-2018, 01:12 PM
By Whacky in forum Auto Detailing 101
Last Post: 03-31-2018, 11:16 PM
By originalgoods13 in forum Auto Detailing 101
Last Post: 02-17-2015, 11:58 AM
By allenk4 in forum Auto Detailing 101
Last Post: 10-04-2013, 02:59 PM
By flawbolt in forum Auto Detailing 101
Last Post: 01-30-2010, 02:12 PM
