Page 5 of 5 FirstFirst 12345
Results 41 to 46 of 46
  1. #41
    Mar 2009
    115
    Re: Foam Cannon HP Foaming Lance for your Pressure Washer
    I want out to one of the home stores and picked up a handel for my Foam cannon. This sames me from chaning the foam guy to a wand each time I want to power wash the house or some thing. It also ware on the threads of the foam gun.
  2. #42
    Aug 2007
    does it work with the Mobiwasher?
  3. #43
    Super Member rwisejr's Avatar
    Apr 2007
    LI NY
    1,099
    Quote Originally Posted by jrc4ever View Post
    From what I see I don't think so .It appears the unit doesn't have enough pressure for one. For two it doesn't have a way to connect the unit as the sprayer looks more like a garden hose than a pressure gun.
    Ron !!!!!
  4. #44
    Jul 2016
    3,328
    so i just pulled the trig on buying this, i already use a soap dispenser that came with my pressure washer, im curious, does the thicker foam mean i dont have to hand wash? i cant see why the foam from the lace cleans any better then the foam from my dispenser? i still hand wash after a quick soak and rinse from the dispenser, seems the big difference will be the amount of foam but does that really mean i wont have to hand wash? i already bought it lol and ill prob hand wash regardless but would appreciate someone clearing this up???
  5. #45
    Aug 2016
    Northern VA
    43
    Quote Originally Posted by fightnews View Post
    I feel this is always a misconception that thicker foam=no need for handwash. The way I've always been told and seen is that you want the foam to be a slightly thinner consistency, as the foam runs down its pulling loose surface debris with it. If you just get thick, shaving cream snowfoam its not always the right thing and is most likely keeping the loose contaminants on the surface until you rinse off.
    but also the type of foam is dependent on many factors(water type, gas/electric pressure washer, GPM rate of said pressure washer)
  6. #46
    Jan 2014
    SoCal
    1,122
    Taking the trip down memory lane. So, did Meghan come back to work for PBMG like some speculated awhile back.
  1. Bought a new pressure washer - need foam lance/gun
    By JMak97008 in forum Auto Detailing 101
    Last Post: 12-19-2018, 03:35 AM
  2. Pressure washer quick disconnect for foam lance
    By PoorOwner in forum Auto Detailing 101
    Last Post: 07-30-2012, 01:39 AM
  3. Costco Snap On pressure washer foam lance fitting?
    By Anto in forum Auto Detailing 101
    Last Post: 07-20-2012, 08:34 AM
  4. Replies: 4
    Last Post: 02-21-2012, 06:17 PM
  5. Replies: 6
    Last Post: 10-28-2011, 03:11 PM
