Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
    Mar 2017
    Southeastern PA
    2,480
    Re: Where does this fit in really?
    Quote Originally Posted by TTQ B4U View Post
    Not sure where I see it's use other than when taking a car that's been waxed and not in need of any further correction but the detailer wants to strip and re-do the vehicle again.
    As someone who does mostly all coatings I don't see a need for this (correct me if I'm wrong) as I'm going to fully strip the car and prep it via polish before the coating anyway.
    am I missing something? I guess I could use this in place of the soap I currently use as a lube when Nano Sponging the vehicles simply because it couldn't hurt to use it. Not sure yet.
    If I’m not mistaken this soap is safe to use on coated cars and will not strip it. So maybe it could be used like twice a year to do a deep clean on the coating? I’m thinking this followed by Iron-X will get the coating back in great shape. Hopefully Nick can confirm this will indeed not affect the coating.
    Bruno Soares
    Mar 2018
    139
    Re: McKee's 37 Coating Prep Auto Wash
    Is it safe to say McKee's 37 Coating Prep Auto Wash is McKees 914 (diluted 8:1) in a soap formula?
    Lakeland -Tampa - St Pete - Clearwater - Sarasota
    Boats / Auto / Trucks / RVs
    863-738-8336 Follow us on Instagram
  3. #13
    McKee's 37 Product Support
    Jan 2011
    7,265
    Quote Originally Posted by ski2 View Post
    Thanks for the info Elliot!! What is the recommended dilution ratio?
    Glug glug method.
    Quote Originally Posted by fightnews View Post
    Can't wait until the testers get to this and find out if it can really strip an lsp....
    From a chemical standpoint, Coating Prep Auto Wash is 3 to 4 times as strong as a normal auto wash. This was made possible thanks to a very advanced alkaline detergent that will help remove remaining traces of previously applied waxes and sealants.
    Will this be effective without a foam gun, 2 bucket method?
    Yes, very effective with either wash method.
    I wonder how much it would strip off any trim sealants?
    Not when used as directed Paul.
    and how much it would impact something like a glass coating.
    Very little impact, if any.
    Quoting myself from the video on the product page: "...what if you're working on something that hasn't been as well maintained as your own vehicle. If you're a detailer, you encounter this situation often. If you have a customer's vehicle that hasn't been properly washed in months, or even years, you NEED a STRONG wash to cut through all that grease, grime, bird droppings, and bug splatter."
    Coating Prep Auto Wash makes the frustrating task of washing a filthy, neglected vehicle easier. In the process, it's going to remove remaining traces of previously applied waxes and sealants.
    I also mention, in the video, that removing old waxes and sealants will improve the performance of your polishing compound.
    The video is only 2 minute and 34 seconds. Check it out.
    Quote Originally Posted by BSoares View Post
    Correct.
    Quote Originally Posted by jolo View Post
    They are very different products.
  4. #14
    Nov 2015
    Los Angeles, California
    13,752
    So it won’t strip off Wolfgang Exterior Trim Sealant, but will strip off McKee’s Hi Def Paint Sealant. Got it.
  5. Likes PaulMys, Elliot@Autogeek liked this post
  6. #15
    Mar 2018
    139
    @ Nick Can you explain the difference? I like Mckee's 914 8:1 for paint prep.
  7. #16
    Sep 2017
    Sweden
    3,022
    What is the ph level on this?
  8. #17
    May 2017
    Pittsburgh PA
    2,847
    Nick underlined “remaining traces”, so I’m guessing it’s not going to strip any strong LSP that is fairly fresh (just my interpretation).
    not sure how this impacts WETS.
  9. #18
    Super Member ski2's Avatar
    Dec 2011
    Southwest PA
    1,826
    Quote Originally Posted by Nick McKees37 View Post
    Glug glug method.
    HaHa, but how many oz per gallon of water are we talking???
  10. #19
    May 2017
    Pittsburgh PA
    2,847
    Directions for use:
    For use with foam guns:Mix 2 ounces of McKee's 37 Coating Prep Auto Wash with 6-8 ounces of water and shake well.
    For use in buckets:Mix 2-3 ounces of McKee's 37 Coating Prep Auto Wash for every 3 gallons of water. Activate with a strong jet of water.
  11. Thanks ski2 thanked for this post
  12. #20
    May 2014
    Northern Vermont
    1,400
    I think Glug-Glug in the Nick scale = 2-3 oz into the bucket (3gal) or foam gun container.
    Sent from my iPad using Tapatalk Pro
  1. McKee’s coating prep wash to rejuvenate coating
    By Coatingsarecrack in forum Auto Detailing 101
    Last Post: 11-19-2019, 05:12 PM
  2. Question on McKee's 37 Coating Prep Polish
    By ivygreen in forum Auto Detailing 101
    Last Post: 04-13-2019, 01:03 AM
  3. McKee's Coating prep ??'s
    By AZpolisher15 in forum Auto Detailing 101
    Last Post: 05-28-2018, 10:16 PM
  4. McKee's Wheel Coating - Prep?
    Last Post: 09-05-2016, 05:50 PM
