» Detailing Classes
Results 21 to 30 of 31
  1. #21
    Senior Member The Guz's Avatar
    Jun 2013
    Lawndale, CA
    6,124
    Re: Poorboys strip down wax stripper
    Quote Originally Posted by Loach View Post
    I'll post this here as well, I had very good results in the first test. I applied Zymol Titanium 3 days ago on the paint (not polish prepped beforehand). Washed today with 1 oz per 1 gallon dilution of Adam's Strip Wash with little impact, strong beading and quick sheeting remained. Sprayed Poorboy's Strip Down when wet on half the hood, went over the area again with the same mitt and the beading was dead during the rinse. No etching marks where it made contact on the paint.
    On my front bumper I've had McKee's 37 SiO2 Paint Coating for 7+ months, extremely strong performance remaining and I tried Strip Down on a section. The coating was significantly damaged in various areas, not full removal but permanently impacted. Very cool, more testing to come!
    Just tried it today on top of 2 weeks old Gyeon Prime and Gyeon One on the other test hood after first trying LA's Totally Awesome APC. LA's didn't do anything to Prime, had a few small patches of damage show up on One. After Strip Down both sections had larger patch areas of damage, One more than Prime. So it's significantly more effective than a strip wash soap at high dilution and at least more effective than LA's TA.
    Just watched your video. The initial performance looks good. But I would be curious if it is leaving surfactants behind that could possibly masking the hydrophobic properties of an LSP. It would be interesting to see an IPA wipe down to see if it is indeed masking or not. I could see it removing old waxes and sealants as they are done anyway after a couple months to a few months.
  2. Likes Loach liked this post
  3. #22
    Nov 2009
    Pasadena, CA
    12,483
    He posted a follow up comment saying he tried an IPA wipe and the water behavor(or lack there of) was nearly the same. This stuff might be legit.
    '03 Corvette Z06
  4. #23
    Apr 2015
    PGH, PA
    1,391
    When I first did all my testing to find out what really stripped an LSP and what didnt using various pH balanced, alkalines , solvents and acid products ..acid being the only product that worked on the product I used ..Autoglym HD..
    I failed tp realize not all waxes and sealants will have the same chemixal resistance..
    Finally did more testing with other products I had in hand angelwax being one of them..
    Some wax/sealants will resist acid and be stripped by solvents ..some will be resistant to solvents but not alkaline etc..
    So to make things more complicated, yeah all these strip type products have a potential to strip an LSP
    My regimen for stripping an LSP while not polishing now incorporates Acid prewash, followed by alkaline, than solvent prep..
    That's about as sure you'll get to stripping an LSP besides abraisives
  5. #24
    Nov 2009
    Pasadena, CA
    12,483
    Quote Originally Posted by Mike@ShineStruck View Post
    What do you use for your acid and alkaline prewash?
    '03 Corvette Z06
  6. #25
    Apr 2015
    PGH, PA
    1,391
    I sometimes use CS-II Dewax, but it's not the cheapest, so usualy only is it for a coating job as thats the first process anyways.
    Feynlab pure wash will do same thing for less
    Been using freaky foam allot lately
    IGL delete would work too
    For the alkaline, any APC would work..I use ADG Fbomb
  7. Thanks WRAPT C5Z06 thanked for this post
  8. #26
    Nov 2009
    Pasadena, CA
    12,483
    Freaky foam claims it won’t strip wax, yet its acidic. LOL
    '03 Corvette Z06
  9. #27
    Apr 2015
    PGH, PA
    1,391
    Yeah, I noticed that too ..but again he could of been testing it on a product that's resistant to acid like Angelwax
  10. #28
    Apr 2015
    PGH, PA
    1,391
    I'll prob do a side by side between the 4
    Dewax
    Pure wash
    Freaky foam
    Delete
    Also another great alkaline product would get IGL Multi
  11. Likes WRAPT C5Z06 liked this post
  12. #29
    Nov 2009
    Pasadena, CA
    12,483
    Dewax
    Pure wash
    Freaky foam
    Delete
    Have you found any LSP that will only be stripped by solvents?
    I would assume Carpro water spot remover will strip any LSP not resistant to acid like the others you mentioned.
    '03 Corvette Z06
  13. #30
    Apr 2015
    PGH, PA
    1,391
    I can do an alkaline test on enigma to see..I've only did acid and solvent on that one.
  1. APC as a stripper
    By mikesal57 in forum Auto Detailing 101
    Last Post: 09-19-2013, 12:10 PM
  2. Stripper scent
    By SYMAWD in forum Auto Detailing 101
    Last Post: 04-04-2013, 06:22 PM
  3. Stripper Scent
    By tdrake2406 in forum Product Reviews
    Last Post: 11-09-2012, 09:04 PM
  4. Wax Stripper
    By bsell in forum Auto Detailing 101
    Last Post: 07-25-2012, 09:48 AM
  5. CG Stripper Scent comes from....
    By CAMAROZL1 in forum Off-Topic
    Last Post: 04-16-2012, 08:51 PM
Members who have read this thread: 49
» July 2019
30 1 2 3 4 5 6
28 29 30 31 123
