New Products at the Geek!
Half long-hair Merino wool, half sheepskin!
Merino Wool Sheepskin DUO Wash Mitt brings you the best of both car washing worlds! Featuring the paint-safe, long-hair Merino wool on one side, and super soft sheepskin on the other, the Merino Wool Sheepskin DUO Wash Mitt really is like having two wash mitts in one! Keep your paint clean and swirl-free when you wash with the Merino Wool Sheepskin DUO Wash Mitt!
Item #: |
WM-128DUO |
Our Price: |
$19.99 |
Sale price: |
$17.99 - You Save $2.00 (10%) |
Mechanically decontaminate even the smallest areas!
Cobra Clay Pad is a 4 inch paint decontaminating pad that uses a hi-tech, rubberized coating to remove surface contaminants from paint on one side, and a hook and loop fabric on the other. Perfect for use with a 3 or 4 inch backing plate, Cobra Clay Pad allows you to clean even the smallest area on your vehicle’s paint. With little to no effort tree sap, over-spray, tar, stubborn road grime, dirt, industrial fall-out, and so much more will be removed from your paint to fully prep your finish.
Item #: |
COBRA-MC4 |
Our Price: |
$24.99 |
Sale price: |
$21.99 - You Save $3.00 (12%) |
A hydrophobic coating car wash!
Stoner Visible Shine Coating Wash is a unique blend of cleaning agents, synthetic lubricants, and durable polymers that come together to create a car wash with paint coating capabilities! Stoner Visible Shine Coating Wash is high-foaming to gently lift away surface contaminants without harm, and contains ultimate hydrophobic technology that repels and sheets water to enhance both the drying time needed, as well as the overall finish. Cut your car wash time in half with Stoner Visible Shine Coating Wash!
Item #: |
STO-91215 |
Our Price: |
$16.99 |
Sale price: |
$14.99 - You Save $2.00 (12%) |
Unique foam pads designed for long-stroke dual action polishers
Lake Country HDO Foam Pads are specially designed foam pads that were developed for long-stroke dual action polishers. With the increasing popularity of long-stroke (also referred to as large throw) dual action polishers, the market demanded a line of foam pads designed specifically for these types of machines. After months of strenuous research and development, Lake Country is proud to introduce the HDO Foam Pads.
Item #: |
LC-HDO-COMBO6 |
Retail Value: |
$95.94 |
Our Price: |
$79.99 - You Save $15.95 (17%) |
Item #: |
LC-HDO-COMBO5 |
Retail Value: |
$83.94 |
Our Price: |
$69.99 - You Save $13.95 (17%) |
Already have the FLEX Kompakt polisher? Time to stock up on the necessary pads and backing plates!
FLEX Kompakt Rotary Pad Kit combines all of the backing plates and pads (and a few extra Polishing Cloths!) you’ll need to use your FLEX Kompakt Rotary Polisher into one kit! The FLEX PE8 Kompakt Rotary Polisher takes the term “surgical buffing” to a new extreme and for that you need the necessary accessories. If you already have the polisher, or if you’re just looking for a refill on your pads and backing plate, the FLEX Kompakt Rotary Pad Kit is perfect for you!
Item #: |
FLEX-555-KIT |
Retail Value: |
$134.38 |
Our Price: |
$99.99 - You Save $34.39 (26%) |
Turn heads and create whiplash for up to two years with this complete paint coating kit
BLACKFIRE shine is unlike anything else available! Until now, the BLACKFIRE shine was restricted to months, but with the advent of Crystal Coat Paint Coating, your vehicle can display the signature whiplash-inducing shine for up to two years! The BLACKFIRE Crystal Coat Paint Coating Kit contains everything you need for proper application of BLACKFIRE Crystal Coat Paint Coating. Fear not, we’ve taken the guesswork out of which applicators work best, and we’ve already included the most important step for applying this revolutionary new coating – Crystal Coat Paint Prep.
Item #: |
BF-5080 |
Retail Value: |
$198.92 |
Our Price: |
$109.99 - You Save $88.93 (45%) |
A paint coating that is applied on wet paint!
Dr. Beasley's Formula 1201 Paint Coating is an advanced polymer based liquid paint coating scientifically designed for modern paint finishes and vinyl wraps. A nano-coating with unrivaled protection, Dr. Beasley's Formula 1201 is applied on wet paint with no need for extended cure times. With just 1 oz. of product needed for an entire car's coating, Dr. Beasley's Formula 1201 provides up to a year's protection with just one application - quite possibly the easiest paint coating you've ever used!
For a limited time only, receive a 4 oz. Dr. Beasley's AdvanceCoat: Gloss FREE with your purchase? Scroll down for more information on Dr. Beasley's AdvanceCoat: Gloss!
Retail Value $39.99!
What is Dr. Beasley's AdvanceCoat: Gloss?
Dr. Beasley's AdvanceCoat:Gloss is a maintenance booster product for nano coatings. It's easy to use and effective. Over time, all nano coatings lose some beading and gloss effects. They've formulated AdvanceCoat: Gloss to extend the life of your coating. Use this maintenance product every 6 months to turn up the gloss, glow, and hydrophobicity. Just spray it on your coated paint and wipe it off!
Item #: |
DB-P38T04 |
Our Price: |
$39.99 |
Re: New Products at the Geek!
Car washes specifically made for paint Coatings are going to be very popular!
2022 Elantra N Cyber Gray
If you're referring to the Stoners, the labeling is a bit confusing. While I'm sure it *can* be used on a coated car, I think the main focus of it is "Coat your car just by washing it".
Yes that is correct. After using the product I mentioned that the wash is not as impressive on a car with a coating on it. I was blown away on a car that had no protection on it. I think the product best suites the average users car.
Hello,
How is this different, or is it the same as using hydro blue every
Originally Posted by waterman
Hello,
Same concept. Wash and protection is left behind. The Stoners is a wash that uses polymer based protection that is left behind. The Hydro Blue is using SiO2 based protection that is left behind, but not a wash.
When is the 3D 505 going to show up in the store?
By DocShine in forum Introduce Yourself
Last Post: 04-20-2014, 12:16 AM
By dane6619 in forum Introduce Yourself
Last Post: 03-06-2013, 09:57 PM
By Mnlc90 in forum Introduce Yourself
Last Post: 02-15-2013, 09:59 PM
By K20A2 in forum Introduce Yourself
Last Post: 06-04-2012, 06:04 AM
By ejflanag in forum Auto Detailing Tools and Accessories
Last Post: 03-04-2008, 08:22 AM
