Page 1 of 2 12 LastLast
Results 1 to 10 of 17
    RUPES Nano iBrid Short Neck - What's in the Box?
    Suggested retail for this bad little boy is $700.00 in U.S. dollars. You can pre-order right now for $560.00 and save $220.00
    So when you pull out your wallet and plunk down your hard earned cash what do you get from RUPES? Well let's take a look at what's inside the box or more specifically, what's inside the tidy carrying case.
    Everything you need to start polishing with surgical precision is included in the kit.
    Battery Charger
    2 li-ION battery packs
    4 each 2" coarse blue foam cutting pads
    6 each 1 1/4" coarse blue foam cutting pads
    One 150 ml bottle of Zephir Coarse Compound
    One 150 ml Keramik Fine Cut Polish
    6 each 1 1/4" yellow foam polishing pads
    4 each 2" yellow foam polishing pads
    One each - 2" backing plate
    One piece design with threaded stud on the back
    One each 1 1/4" backing plate
    One each nylon scrubbing brush
    One each soft bristle brush
    Wrench
    1 1/4" backing plate for sanding discs
    10 each #2000 grit sanding discs
    10 each #3000 grit sanding discs
    AC-DC Adapter
    BigFoot Premium Tool Case
    Full RUPES documentation
    Re: RUPES Nano iBrid Short Neck - What's in the Box?
    Continued...
    Rotary backing plate connector
    12mm orbit connector
    3mm Orbit Connector
    Quality NSK bearings
    The plastic shroud is made to be removed when swapping out heads...
    There's a notch on two sides of the head unit
    And a two tabs on the inside of the plastic shroud that slip into the notch.
    Spindle locking button
    Speed dial
    Size comparison
    To give you an idea of the size of the iBrid Nano here it is next to a RUPES Mini 12mm
    Order yours now on Autogeek.com
    Rupes Bigfoot Nano iBrid Short Neck Kit
    Pre-Order Special!
    Aug 2010
    New Jersey
    15,142
    Glad you finally got yours, Mike.
    Newbie Member VitreousHumor's Avatar
    Aug 2015
    Thank you, Mike!
    What a meticulous and thorough presentation! Makes me want to immediate order this tool.
    Feb 2014
    Rochester MA
    2,627
    That is awesome! Really starting to dig this thing.
    IGL Authorized Coating/Kenzo Installer
    Final Inspection Auto Detailing- https://www.facebook.com/FinalInspection
    Aug 2011
    Reisterstown MD
    1,128
    I've used mine several times and can't say enough about it! An extremely effective and high quality machine.
    Quote Originally Posted by Mike lambert View Post
    Good to hear your opinion Mike.
    Question?
    What do you think about the power of the tool to maintain pad rotation and oscillation when using the 2" pad with the 12mm orbital connector?
    Aug 2011
    Reisterstown MD
    1,128
    I found you have to keep an eye on the pressure you put on the pad. It takes a little getting used to with such a small machine.
    Apr 2015
    PGH, PA
    1,482
    You don't need to remove the plastic shroud
    Just hand thread on then use spanner wrench..
    I did a quick test with mine before I send it back to Rupes for exchange
  10. #10
    Quote Originally Posted by nothingface5384 View Post
    I was simply showing the tool and its components.
    When I tried to use the 2" backing plate with the rotary backing plate connector the back of the backing plate rubbed against the shroud. In fact the contact was so tight the backing plate would not spin.
    The instruction manual doesn't offer any substantial information about the tool including whether or not the shroud should be in place at all time or removed when used as a rotary polisher. There's nothing on these topics.
    I removed the shroud so I could use the rotary backing plate and after attaching the backing plate with the shroud removed it functioned just fine.
    Maybe I over tightened the rotary backing plate connector and the backing plate causing the backing plate to contact to tightly against the shroud?
    I'm actually very mechanically inclined, enough to rebuild engines, brakes and do all my own mechanical work on my own trucks so I kind of doubt I over-tightened but... maybe.
    Tried to call Todd Helme and Jason Rose for their input but no answer.
  1. Rupes Bigfoot ibrid nano long or short neck
    By patricemougeot in forum RUPES BigFoot Oribital Polishers
    Last Post: 07-04-2018, 01:44 PM
  2. Rupes Bigfoot Nano iBrid Short or Long Neck
    By theamcguy in forum RUPES BigFoot Oribital Polishers
    Last Post: 09-09-2017, 07:03 PM
  3. Replies: 4
    Last Post: 07-25-2017, 05:02 AM
  4. Replies: 25
    Last Post: 01-14-2017, 02:43 AM
  5. RUPES Nano iBrid Short Neck - What's in the Box?
    By Mike Phillips in forum New Car Care Products
    Last Post: 05-19-2016, 10:56 AM
