» Detailing Classes
Page 5 of 6 FirstFirst 123456 LastLast
Results 41 to 50 of 53
  1. #41
    Senior Member Coatingsarecrack's Avatar
    Dec 2018
    1,395
    Re: Mckees Tire Coating: Thoughts and compare with Gloss Tire Gel
    Give it a shot. You won't be disappointed in it. I've mentioned a few times that I have gone a year with this tire coating and it was still present on the tire and could have gone even longer. I touched it up 1 year later. Seems like Nick has made this version even better than the original detailer's pro version.
    Also that different tire compounds will take the coating differently.
    I prefer McKee's over Tuf Shine in looks and performance.
    Yeah I had it down to mckees, optimum and black pearl. Optimum doesnít seem to be better and Perl is a lot more. Another reason itís mckees is I going to try the Tac systems tire coat as a monthly- bi monthly topper as both are acrylic resins (not sure of others) and I gotta use it for something
  2. #42
    Member
    Nov 2018
    74
    what steps are involved in touching them up? Mine still look okay after 6 months, but would like to touch them up also.
  3. #43
    Senior Member acuRAS82's Avatar
    May 2017
    Pittsburgh PA
    1,601
    Quote Originally Posted by mrmarkmac View Post
    I think you can reapply, by not stripping the existing coating, i.e. using a softer brush with the tire cleaner spray. This should quickly clean the existing coating and itís ready to be topped. Less work than throwing the kitchen sink at the tires every time you re-apply.
    Honestly, even using something like water and Mckees Prep Wash could leave coated tires clean enough to recoat. Way easier than cleaning bare rubber. Iíve used the prep wash before but ended up also using the tire cleaner spray after... the spray proved the tires were pretty clean after the prep wash (no brown foam).
    What region do you live in, mrmarkmac? Just curious based on your 6 month duration.
  4. #44
    Senior Member The Guz's Avatar
    Jun 2013
    Lawndale, CA
    6,441
    From what I have seen and read, optimum seems to be streaky and splotchy.
    I use the Tuf shine applicators to apply Mckeeís.
    I just use soap in my wheel bucket and a soft bristled brush to remove any surface dirt. Then I use the metro vac side kick to dry the tires and apply a fresh coat or two, using the sidekick in between coats to speed up the tire coating drying time.
  5. Likes vincec, acuRAS82 liked this post
  6. #45
    Member
    Nov 2018
    74
    Iím currently in Texas. The car is in the garage more than out and probably only 3,000 miles in those 6 months, and never rain. I was more interested in touching them up because I only did one coat originally and after doing my wifeís car with 3 coats, they look a lot better.
    given mine are clean from washing regularly, Iíll just hit them with soap and agitate it before drying and reapplying.
  7. Thanks acuRAS82 thanked for this post
  8. #46
    Senior Member Mad Wax's Avatar
    Sep 2014
    326
    Prep is key. After degreasing the tire, go over it with laquer thiiner, or mineral spirits until there's no black gunk on the towel. Then apply the tire coating. There's no degreaser on the market that will get that stuff off, no matter how many times you scrub.
  9. #47
    Senior Member Rsurfer's Avatar
    Jan 2007
    12,119
    I’m currently in Texas. The car is in the garage more than out and probably only 3,000 miles in those 6 months, and never rain. I was more interested in touching them up because I only did one coat originally and after doing my wife’s car with 3 coats, they look a lot better.
    given mine are clean from washing regularly, I’ll just hit them with soap and agitate it before drying and reapplying.
    Quote Originally Posted by Mad Wax View Post
    Is all that prep necessary for a touch up?
  10. #48
    Jun 2013
    Lawndale, CA
    6,441
    No it is not. The coating makes it easier to keep the dirt off the surface. I have yet to do the entire prep just for a touch up.
  11. #49
    Sep 2014
    326
    Not for touch up....for the first original application.
  12. #50
    Jan 2007
    12,119
    Quote Originally Posted by vincec View Post
    I had the same thing happen on my truck that had been treated for a year fairly regularly with Hot Shine the first time I tried McKee's Tire Coating. I had to use a strong APC full strength on the tires with a stiff brush multiple times followed up with McKee's Tire and Rubber Rejuvenator for the last cleaning. All I use now is tire coating and after the initial cleaning the browning issues went away. I'm getting 4 to 5 months or longer out of McKee's Tire Coating and just purchased another large bottle. On the next application on my wife's Durango I'm going to power scrub the tires with APC followed by the T&R Rejuvenator and start with a clean slate. This vehicle has Goodyear Fortera tires from the factory and they don't take the tire coating as well as my other two vehicles. The Goodyear tires on my Ram look great all the time and the Michelin tires on my work vehicle look good with a single coat applied. I've read in other threads make and model of tire can effect the outcome when using this coating.
    Yep, all tires are not created equal just as not all paint are created equal.
  1. Replies: 31
    Last Post: 05-27-2018, 12:06 AM
  2. McKees Gloss tire gel
    By karmzac in forum McKees 37
    Last Post: 11-25-2017, 05:23 PM
  3. McKees Tire Coating
    By milenkod in forum McKees 37
    Last Post: 11-14-2017, 09:31 PM
  4. Review - McKees Gloss Tire Gel
    By briarpatch in forum Product Reviews
    Last Post: 07-24-2017, 07:41 AM
  5. Brief Thoughts: DP Tire Gloss Gel
    By mavin in forum Product Reviews
    Last Post: 08-24-2013, 11:02 PM
Members who have read this thread: 89
» December 2019
1 2 3 4 5 6 7
8 9 10 11 12 13 14
15 16 17 18 19 20 21
22 23 24 25 26 27 28
29 30 31 1234
