» Detailing Classes
Results 1 to 9 of 9
    Jun 2009
    Stuart, Florida
    46,954
    Video Class: Tire Coatings - Machine Scrubbing Tires - BEFORE & AFTER Pictures
    Here's the video from this LIVE DETAILING CLASS
    Here's the tools and products I'll be showcasing for this online detailing class.
    Pinnacle Black Label Products
    Complete PBL Tire Coating Kit
    Pinnacle Black Label Complete Tire Coating Kit
    Individual products
    Pinnacle Black Label Tire Clear Coat
    Pinnacle Black Label Gel Tire Cleaner 8 oz
    Griots Garage Hand Wax Applicators, Set of 3
    Tuf Shine Products
    Complete Tuf Shine Tire Coating Kit
    TUF SHINE Tire Appearance Kit
    Individual products
    TUF SHINE Tire Clearcoat
    TUF SHINE Tire Cleaner 22 ounce
    TUF SHINE Tire Brush
    Machine Scrubbing
    FLEX PE-150 Cordless Rotary Polisher
    Heavy-Duty DA Carpet Brush – Long Bristles
    Rotary 4 ľ inch Flexible Backing Plate
    Mike Phillips Facebook Page
    Twitter
    Instagram
    Mike Phillips Detail Training Credentials
    Jun 2009
    Stuart, Florida
    46,954
    Re:Video Class: Tire Coatings - Machine Scrubbing Tires - BEFORE & AFTER Pictures
    Before and After Pictures
    Pinnacle Black Label Tire Cleaner and Tire Clear Coat
    Driver's side front tire
    This tire was machine scrubbed 3-4 times with Pinnacle Black Label Tire Cleaner and then ONE application of the Pinnacle Black Label Tire Clear Coat was applied.
    BEFORE
    After cleaning only
    AFTER one application of the PBL Tire Clear Coat
    Passenger side front tire
    This tire was machine scrubbed 3-4 times with Pinnacle Black Label Tire Cleaner and then TWO applications of the Pinnacle Black Label Tire Clear Coat was applied.
    Before
    After 2 applications of PBL Tire Clear Coat
    Passenger side rear tire
    This tire was machine scrubbed 3-4 times with Tuf Shine Tire Cleaner and then FIVE applications of the Tuf Shine Tire Coating was applied.
    BEFORE
    AFTER
    Driver's side rear tire
    This tire was machine scrubbed 3-4 times with Tuf Shine Tire Cleaner and then SIX applications of the Tuf Shine Tire Coating was applied.
    BEFORE
    AFTER
    Final results for this 1932 Ford Highboy Deuce Roadster
    The PBL Tire Clear Coat Kit
    The Tuf Shine Kit plus everything I used to clean the tires and apply the coating
    Behind the scenes
    Here's Yancy setting up...
    I took this picture right before we started the LIVE DETAILING CLASS
    We actually shared more tips, techniques and information in this one video than in any of our 1/2 hour TV shows. Of course I don't have the beautiful AJ to stand around and look pretty but if you want MEATY info - that's what's shared.
    2" x 4" chunk of wood about 16" long with the ends cut at 45 degrees
    Twitter
    Instagram
    Mar 2020
    We're you using Tuf shine also on the tire?
    Jun 2009
    Stuart, Florida
    46,954
    Re: Video Class: Tire Coatings - Machine Scrubbing Tires - BEFORE & AFTER Pictures
    Quote Originally Posted by Blacklightn25 View Post
    I used the Tuf Shine brand cleaner and coating on the back tires.
    I used the PBL Tire Clear Coat cleaner and coating on the front tires.
    I have AMAZING before and after pictures to share but I have a new product to review that I must process the pictures and then write before EOD.
    Stay tuned....
    Twitter
    Instagram
    Mar 2018
    Conroe, Texas
    318
    My test tires used the Tuff Shine and I did have reasonable luck with 6+ months on those tires. Yes they did get dirty between washes but using regular soap they cleaned off back to matte finish.
    My only gripe is all the PREP work to make sure they tires are totally clean! Doing it with my drill brush setup and 5-times on each tire still is lots of labor and sweat equity. Worth it over time but the day you do a proper cleaning takes time. I think I have heard that is worth about $75/tire if were to do this as part of a detailing business. I guess the proper response is to offer it at a lower price, perhaps $10/tire and give the customer the brush and tell him 'get' scrubbing! Provide the supplies and let him do the first one by himself. Bet that many will walk away.
    See, I hate that prep work! LOL
    And do follow the directions on the Tuff Shine Coating, do not use aggressive chemicals or cleaners after applying this product. It will not last and I have a YouTuber that can attest to the lesson. They did admit they should have read them afterwards.
    Hump day, and it's my Friday off!
    Jun 2009
    Stuart, Florida
    46,954
    Quote Originally Posted by Thomkirby View Post
    I get much longer. But I apply 5-6 coats.
    Yep - just car wash soap and water. You cold even use a spray detailer or waterless wash to clean the coating.
    Wait until you get your rotary and the brush. It's still work but it's so much easier on you than trying to hold a drill with a brush on the end and it's so POWERFUL.
    I've done $50.00 so $200.00 for a set of 4 tires. With the cordless rotary it goes a lot faster. I like the idea of $300.00 better.
    Even if your customer has the muscle and inclination - without training or watching the above video they would be lost on what to do and how to properly do it.
    Thanks for commenting Kirby.
    Twitter
    Instagram
    Senior Member BSoares's Avatar
    Mar 2017
    Exton, PA
    1,537
    On videos/pictures that front driver's side tire done with PBL instead of Tuffshine looks a lot less glossy than the tires done with Tuffshine. Is it like that too in person?
    It seems like a lot of work, even with a machine to do the scrubbing, seems like more work than I'd be willing to put into tires. I don't mind applying a dressing every time I wash.
    Bruno Soares
    Jun 2009
    Stuart, Florida
    46,954
    Quote Originally Posted by BSoares View Post
    Yes - but that was the goal. AND - On the driver's side I only applied one coat or one application, like you saw in the video. On the passenger side front time I wiped around the tire twice.
    The PBL is supposed to be one-and-done. Faster and easier.
    The Tuf Shine process I did takes a lot more time and some people don't like their tires to look like glossy black plastic. (I do)
    Copy that.
    There is a LOT more work up front but to me the dividends pay off big time. No messy, oily, greasy tire sidewalls.
    But - that's just me.
    Twitter
    Instagram
  9. Likes BSoares liked this post
  10. #9
    Jun 2009
    Stuart, Florida
    46,954
    As I walk out the door, I'll take a picture of some tires I coated at least 6 months ago for an all original 1970 Corvette.
    Twitter
    Instagram
  1. Which color brush best for DA Polisher tire scrubbing?
    By SwedishRider in forum Ask Mike Phillips your detailing questions!
    Last Post: 10-15-2017, 01:17 AM
  2. Replies: 28
    Last Post: 03-21-2017, 08:20 AM
  3. Tires still brown after scrubbing...
    By rockford33 in forum Auto Detailing 101
    Last Post: 09-12-2011, 10:07 PM
  4. Applying tire shine: pic and video!!!
    By shadybreal in forum Auto Detailing 101
    Last Post: 06-27-2007, 06:02 AM
Members who have read this thread: 55
» July 2020
