Results 1 to 5 of 5
Thread: A beginner
    Apr 2018
    A beginner
    Getting my first Da polisher. I figure a cheap harbor fraight will do to learn on. Have always been scared to use a machine. Lol
    going with lake county 3” backing plate & 3 1/2” foam pads. Will be using on a Harley Davidson Ultra Classic vivid black.
    plan on using megurie d300, HD speed & collinite 845. Hope this is a good combo to learn.
    bike has moderate scratches & swirls.
    time to read and learn, thanks for helping us common folks learn detailing.
    Re: A beginner
    Quote Originally Posted by Bigdawg580 View Post
    Welcome to AutogeekOnline!
    There are a ton of foam pads on the market and while the HF polisher has the power to rotate thick pads I would still encourage you to get thin foam pads for your 3" backing plate.
    Here's what happens to thick foam pads without a taper - the face of the pad twists inward turning a 3.5" pad into a 3" pad. It just not a good buffing experience. With a thin pad, there's no extra foam to twist inward so it retains its shape and you maintaint a flat pad against the surface. I think you'll find this to be a much better buffing experience your first time out.
    Here's the link to two brands of thin foam pads, either are good...
    Lake Country ThinPro Foam Pad System 3.5 Inch
    Griots Garage 3 inch BOSS Foam and Microfiber Pads
    Here's the Griot's Conversion Kit and this will fit on your HF polisher
    3 inch Griot's Garage BOSS Pad Conversion Kit
  3. Thanks Dan Tran thanked for this post
  4. #3
    Super Member Paul A.'s Avatar
    Dec 2007
    Tampa Florida
    5,274
    Re: A beginner
    Welcome into the clubhouse, BigDawg580! Lots and lots of great info, learning tips and guidance right here. It's easier than you think.
  5. #4
    Regular Member Natron's Avatar
    Dec 2013
    Carterville, Il.
    151
    Re: A beginner
    Welcome, don't be scared. Do a little research and have a little fun.
    Nathan Doering CD-SV
  6. #5
    Aug 2013
    Tustin, CA
    4,389
    Re: A beginner
    Welcome to AGO! Have Fun and Rock while you do!
    CJ
    Save the Manual!
  1. Beginner: What to buy?
    By Calendyr in forum Products Guides
    Last Post: 06-18-2013, 01:02 AM
  2. Beginner need help!
    By Jmoran in forum Auto Detailing 101
    Last Post: 06-09-2012, 11:12 PM
  3. What is the best for beginner?
    By xxnonamexx in forum Porter Cable 7424XP Dual Action Orbital Polisher
    Last Post: 05-26-2011, 09:00 PM
  4. Replies: 4
    Last Post: 05-19-2011, 06:48 PM
  5. A beginner needs some help!
    By P1et in forum Auto Detailing 101
    Last Post: 08-11-2006, 06:46 PM
