» Detailing Classes
Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
    Senior Member LSNAutoDetailing's Avatar
    Jun 2014
    Chandler, AZ
    3,120
    Re: How To RESTORE your Headlights the PROPER way!
    Just did mine yesterday. DLUX for LSP.
    Before:
    After:
    Please excuse the typos. Sent from my iPhone using Tapatalk
    Paul_G www.lsnautodetail.com IDA CD-SV
    Senior Member Rsurfer's Avatar
    Jan 2007
    11,644
    Quote Originally Posted by rlmccarty2000 View Post
    How long does Opti-lens last? Or McKees? Is there something in a spray can that lasts longer that anyone knows about?
    Clear coat comes in a spray can, but why would anyone want to spray and have to cover up everything in sight.
  3. #13
    Jan 2007
    11,644
    Quote Originally Posted by LSNAutoDetailing View Post
    Before:
    After:
    Nice, I put 2 coats of Dlux and it's over a year with no yellowing/hazing. And it sits outside 24/7.
  4. #14
    Apr 2015
    PGH, PA
    1,337
    I tier my HLR as every customer doesn't care to haver perfect, just clear.
    My level one is Just a compound /wool, it acts as a test spot to help you decide what really needs done if customer opted for higher service
    LC purple foam wool, blue foamed wool, or carpro cool wool will all work.
    Scholles S0 compound and drill
    Panel prep
    Ceramic coating..
    If above service results left blotchy/haze areas I'll proceed to 600 dry, 1500wet, compound, panel prep, then wipe on UV coating..
    If above prcesst left crazing/crow feet (hazing with micro cracks) I'll start at 320, 500,800 (sometimes 1000)prep, then 2k clear..
    Obviously all are at different price points and carry different length warranties.
  5. #15
    Senior Member Stevedotmil's Avatar
    Feb 2013
    Columbia, SC
    116
    I just did the headlights on my 1995 Accord wagon. My 16y/o son drives it so I couldn’t let him drive at night with hazy headlights. I used Dlux for the LSP as well.
    https://www.facebook.com/newfinishPDLLC/
    Steve Infante, New Finish Columbia 803-553-1782
    Columbia, SC / IG:@newfinishcolumbia
  6. #16
    Jul 2013
    Apex, NC
    1,112
    The SiO2 coatings don't last as long as applying a new UV coating like the factory coating. They smell like they are urethane based loaded and with UVA/UVB. There are wipe on ones too. You don't have to spray them on. I apply them after a compounding step that followed what ever sanding was needed. The hazing from compounding seems to be enough for the UV coating to adhere to. I do not use a fine polish to finish to a high gloss.
  7. #17
    Senior Member Desertnate's Avatar
    Aug 2013
    St Louis metro (Illinois)
    3,610
    I’ve been using Meguires Headlight Coating and it is supposed to last a year. How long does Opti-lens last? Or McKees? Is there something in a spray can that lasts longer that anyone knows about?
    On my daughter's Mazda, the Meguiars coating lasted about 4~5 months before the lenses started to yellow again. I've used the Wolfgang headlight kit and the sealant provided in that kit lasted 6~7 months.
    Save the Manuals!!
  1. How do YOU restore headlights?
    By KyleWrap in forum Products Guides
    Last Post: 03-14-2015, 08:19 PM
  2. How to restore my headlights
    By BrianMcLeod in forum Auto Detailing 101
    Last Post: 11-12-2014, 06:14 PM
  3. The best way to restore headlights
    By Wes45 in forum Ask Mike Phillips your detailing questions!
    Last Post: 11-04-2014, 10:38 AM
  4. Headlights restore
    By barry50208 in forum Auto Detailing 101
    Last Post: 10-11-2013, 02:14 PM
  5. Should I restore my headlights?
    By LincolnZephyr2006 in forum Auto Detailing 101
    Last Post: 12-22-2009, 01:39 PM
Members who have read this thread: 147
» March 2019
2425262728 1 2
3 4 5 6 7 8 9
10 11 12 13 14 15 16
17 18 19 20 21 22 23
24 25 26 27 28 29 30
31 123456
