» Detailing Classes
Page 1 of 2 12 LastLast
Results 1 to 10 of 20
    360Detail.com Kris R's Avatar
    Nov 2008
    577
    How to build an awesome mobile rig.
    I toyed around with buying skid mounted equipment or even looked at a rightlook trailer. You can build your own for less than half. I started with a custom build 6x10 trailer. I probably could have done a 5x8 but I utilized the extra space for a work bench. How to build an awesome mobile rig.-imageuploadedbyagonline1448246583-134076-jpgHow to build an awesome mobile rig.-imageuploadedbyagonline1448246608-280220-jpgHow to build an awesome mobile rig.-imageuploadedbyagonline1448246626-776829-jpgHow to build an awesome mobile rig.-imageuploadedbyagonline1448246644-300470-jpgHow to build an awesome mobile rig.-imageuploadedbyagonline1448246698-377469-jpg
    Drove 2 hours to GA to the factory to pick this up. First thing I did was install the rims I bought for it. How to build an awesome mobile rig.-imageuploadedbyagonline1448246789-260832-jpgHow to build an awesome mobile rig.-imageuploadedbyagonline1448246803-766344-jpgHow to build an awesome mobile rig.-imageuploadedbyagonline1448246813-969439-jpg
    I pretty much ordered everything on line. I upgraded the pressure washer. How to build an awesome mobile rig.-imageuploadedbyagonline1448246924-090272-jpgHow to build an awesome mobile rig.-imageuploadedbyagonline1448246936-946537-jpgHow to build an awesome mobile rig.-imageuploadedbyagonline1448246957-853970-jpg
    I only use ethanol free fuel and used royal people oil. How to build an awesome mobile rig.-imageuploadedbyagonline1448247015-833269-jpgHow to build an awesome mobile rig.-imageuploadedbyagonline1448247040-398066-jpg
    I run tornador tools, pneumatic tools, so I opted for a gas powered compressor. 13.7 cfm. Never runs out of air. How to build an awesome mobile rig.-imageuploadedbyagonline1448247128-092750-jpgHow to build an awesome mobile rig.-imageuploadedbyagonline1448247140-193531-jpgHow to build an awesome mobile rig.-imageuploadedbyagonline1448247190-956877-jpg
    Picked up a great generator, electric start, on Amazon. Great deal. Powers my vx5000 steamer no problem. That steamer trips almost every home breaker in every customers house I plug it into so that's saying something.
    How to build an awesome mobile rig.-imageuploadedbyagonline1448247279-845078-jpgHow to build an awesome mobile rig.-imageuploadedbyagonline1448247293-923267-jpgHow to build an awesome mobile rig.-imageuploadedbyagonline1448247309-309358-jpgHow to build an awesome mobile rig.-imageuploadedbyagonline1448247321-230108-jpgHow to build an awesome mobile rig.-imageuploadedbyagonline1448247347-147878-jpgHow to build an awesome mobile rig.-imageuploadedbyagonline1448247362-086437-jpg I bought a 65gal tank. This is almost 500lbs full and my trailer is single axle and has other equipment. Got to keep the weight down. I installed a automatic shut off valve in the tank. A bypass feed from the pump to the tank. Inline filter from tank to pump, and installed a separate hose to fill up buckets or have running water.
    More soon.
    Kris R
    360detail.com
    Sep 2015
    6,281
    Re: How to build an awesome mobile rig.
    Quote Originally Posted by Kris R View Post
    More soon.
    pretty cool
    Nov 2008
    577
    How to build an awesome mobile rig.-imageuploadedbyagonline1448247729-488127-jpgHow to build an awesome mobile rig.-imageuploadedbyagonline1448247745-330061-jpgHow to build an awesome mobile rig.-imageuploadedbyagonline1448247756-051651-jpgHow to build an awesome mobile rig.-imageuploadedbyagonline1448247776-011288-jpgHow to build an awesome mobile rig.-imageuploadedbyagonline1448247789-268282-jpgHow to build an awesome mobile rig.-imageuploadedbyagonline1448247849-581567-jpgHow to build an awesome mobile rig.-imageuploadedbyagonline1448247869-374981-jpgHow to build an awesome mobile rig.-imageuploadedbyagonline1448247883-249150-jpgHow to build an awesome mobile rig.-imageuploadedbyagonline1448247905-276374-jpgHow to build an awesome mobile rig.-imageuploadedbyagonline1448247927-304533-jpg
    I built this shelf out of poplar and 2x4s then used spray on BEDLINER for the coating. This holds my air hose and pressure washer hose reels.
    How to build an awesome mobile rig.-imageuploadedbyagonline1448248044-196313-jpg
    With 3 gas powered machines in the back I figured a good extinguisher by the front door was in order.
    How to build an awesome mobile rig.-imageuploadedbyagonline1448248118-550826-jpgHow to build an awesome mobile rig.-imageuploadedbyagonline1448248141-128754-jpg
    I built another shelf and painted it blue. How to build an awesome mobile rig.-imageuploadedbyagonline1448248196-372993-jpg lastly I decided to built a bench that goes over the water tank. Got to make use of vertical space.
    How to build an awesome mobile rig.-imageuploadedbyagonline1448248252-284695-jpgHow to build an awesome mobile rig.-imageuploadedbyagonline1448248263-722038-jpgHow to build an awesome mobile rig.-imageuploadedbyagonline1448248283-216567-jpgHow to build an awesome mobile rig.-imageuploadedbyagonline1448248309-546724-jpgHow to build an awesome mobile rig.-imageuploadedbyagonline1448248331-157726-jpg
    At this point I still needed more storage space. Stuff was sliding all over the place. So another shelf it was!
    How to build an awesome mobile rig.-imageuploadedbyagonline1448248397-175115-jpg
    This was bolted to the walls and studs. I also built walls around each shelf to keep things from sliding off. How to build an awesome mobile rig.-imageuploadedbyagonline1448248470-076109-jpg
    Next thing to do was design the wrap graphics. How to build an awesome mobile rig.-imageuploadedbyagonline1448248547-082982-jpgHow to build an awesome mobile rig.-imageuploadedbyagonline1448248563-509782-jpgHow to build an awesome mobile rig.-imageuploadedbyagonline1448248587-952688-jpgHow to build an awesome mobile rig.-imageuploadedbyagonline1448248605-945953-jpg
    Attached Thumbnails Attached Thumbnails How to build an awesome mobile rig.-imageuploadedbyagonline1448248712-581356-jpg
    Kris R
    360detail.com
    Nov 2008
    577
    I decided to extend the drain valve and lines on the compressor and install a water separator. Put some clamps on some hose fittings and hung my Autogeek banner. How to build an awesome mobile rig.-imageuploadedbyagonline1448248781-768020-jpgHow to build an awesome mobile rig.-imageuploadedbyagonline1448248795-776129-jpgHow to build an awesome mobile rig.-imageuploadedbyagonline1448248809-530497-jpgHow to build an awesome mobile rig.-imageuploadedbyagonline1448248821-837328-jpgHow to build an awesome mobile rig.-imageuploadedbyagonline1448248833-427308-jpgHow to build an awesome mobile rig.-imageuploadedbyagonline1448248856-022654-jpgHow to build an awesome mobile rig.-imageuploadedbyagonline1448248871-796471-jpg
    Thanks for viewing!
    Kris R
    360detail.com
    Senior Member Joshwaa's Avatar
    Nov 2015
    Lake Worth, FL
    172
    That looks awesome. Might want to consider pointing the exhausts out of the back of the trailer.
    2016 Ram 1500 4x4 Laramie CrewCab w/Air Suspension
    2014 Nissan Pathfinder Platinum Hybrid
    Nov 2008
    577
    All the equipment is at the back door. All exhaust ports point away from walls or towards the back. There's a large space between the generator and pressure washer. These two machines are never running simultaneously. Been using this set up for months with no issues. Eventually I plan on running exhaust down through the floor and out the sides.
    Kris R
    360detail.com
    Senior Member dcjredline's Avatar
    Mar 2012
    Upstate NY
    3,203
    Geeeeeeeeeeeeeeeeeesh, how much business do you do a week/month? Looks like you have more there than I have in my garage at home! Nice set up.
    "Dirt likes detergent so much better than the surface that it's attached to, it'll leave that surface to go hang out with the soap"...aim4squirrels
    Nov 2008
    577
    Right now anywhere from 400-1200 a week. I work at the fire station every 3rd day and detail on my off days. I expect it to pick up a bit now that I got the trailer wrapped.
    Kris R
    360detail.com
    Senior Member AZ Mike's Avatar
    Jan 2014
    Phoenix, Arizona
    1,128
    That is a mice set up. Thanks for sharing.
    AZ Mike aka "Repeat"
  10. #10
    Nov 2014
    thanks a lot to share us.
    and nice job you have done on that trailer, what truck or car you use to move it.
  1. Replies: 54
    Last Post: 07-17-2020, 09:14 PM
  2. Wax build up..............
    By Rivertender in forum Ask Mike Phillips your detailing questions!
    Last Post: 05-06-2016, 06:39 PM
  3. If you build it...it will run!
    By MrCleanit in forum Off-Topic
    Last Post: 01-01-2013, 11:44 PM
  4. Moving to a Toyota Tacoma for mobile detailing, help me build it!
    By anson89 in forum How to make money detailing cars
    Last Post: 07-20-2011, 10:42 PM
  5. wax build up
    By kimandbrad21 in forum Auto Detailing 101
    Last Post: 07-03-2010, 11:49 AM
» September 2020
3031 1 2 3 4 5
6 7 8 9 10 11 12
13 14 15 16 17 18 19
20 21 22 23 24 25 26
27 28 29 30 123
