Page 1 of 2 12 LastLast
Results 1 to 10 of 11
    Super Member Kyle@PrecisionPolish's Avatar
    Mar 2013
    220
    Am I missing anything?
    Karcher X series Pressure washer
    MTM Foam Cannon foam cannon
    75 gal water tank water tank
    honda eu200i generator
    CG Maxi Suds Soap
    Bucket
    carpro wool mitt mitt
    gold plush micro-Chineelle wash mitt mitt
    Grit Guard Pad Washer pad washer
    Micro fiber towel
    Micro fiber towel still working on it
    Micro fiber towel
    Mothers wheel brush combo brushes
    Daytona speed master jr brush brushes
    Blackfire total eclipse wheel dressing
    ONRWW rinseless wash
    Iron X Decon
    DP clay clay
    3M trim tape 3 pac tape
    Optimum metal polish metal polish
    M101 Heavy compound
    Optimum Polish 2 medium/light compound
    HD Speed AIO
    CG EZ crčme glaze glaze
    Optimum Opti-Seal Sealant
    Sealant Upgrade sealant?
    Collonite 845 Wax
    Blackfire BlackICE Wax/sealant
    Griots V3 DA DA
    pads
    pads ????
    pads
    Indigo 6 inch microfiber bonnets bonnets
    DP Engine Degreaser engine degreaser
    DP trim detailer Exterior trim detailer
    metro vac n blo vacuum
    VX 5000 (renny upgrade) steamer
    Sonax upholstery cleaner carpet cleaner
    mothers VLR vinyl/leather/plastic protectant
    quikshade instant canopy (custom) canopy
    I'm getting down to the final list of what I need, this is what I have so far. If you can think of anything else I might need or don't actually need let me know.
    I'll have the vx5000. Do you think I will need the Sonax for the heavier stains?
    I know ONRWW can be diluted for glass cleaner, spray detail and clay lube. What ratios do you guys use and can it be used for anything additional?
    thank you for the input guys.
    Super Member thebamboo23's Avatar
    Dec 2012
    Houston, Tx
    1,122
    Re: Am I missing anything?
    Is this all for self use or business?
    Feb 2011
    Minot, ND
    12,365
    For pads I really like the hydrotech's.
    For a sealant try out Menzerna PowerLock
    Mar 2013
    220
    business use
    Super Member VP Mark's Avatar
    Jul 2012
    2,451
    I don't see an APC? If I were you I would skip the detailers pride engine stuff and get a gallon of Meguiar's APC+. It will do engines, wheel wells, tires, wheels, carpet pre treatment, carpet spot cleaner, etc. etc..
    Visual Pro Detailing - Auto Detailing near Marion, IL. Call
    (618) 983-9706 www.visualprodetailing.com
    Dec 2012
    Houston, Tx
    1,122
    -what about a pump for the pressure washer?
    -APC? look into a super degreaser and a normal apc
    -ditch the engine/exterior cleaner.. thats what the apc is for diluted at the correct ratio. ie 1:1 10:1 4:1 etc
    -5" backing plate and 5.5" pads larger areas
    -3" backing plate and 3.5" pads for tight areas
    -for the foam cannon you should have solution for stripping wax and solution for normal wash
    -leather aio
    -again, the sonax could be ditched for the apc diluted the correct ratio
    -you should use distilled water for anything you dilute
    -when adding solution into the cannon, make sure its warm water
    -metro vac n blo vacuum- i would ditch that and get the sidekick for the tight areas.. people say the blower on that is weak.. but look into that
    -medium and agressive grade clay.. you never know..look into the speedy prep towel
    -extension cord
    -make sure your generator has enough power for all your equipment
    -different light to inspect paint and light the area of work. i.e. brinkman, led, halogen, headlight
    -any brushes in mind? for the cracks, grills, vents, cup holders, handles, etc..
    trying to give you as much suggestion as possible
    Super Member rmagnus's Avatar
    May 2011
    SoCal
    1,446
    Polishers DA & Rotary
    Brushes wheel, tire, interior & engine bay
    Air compressor for compressed air (interior work)
    D151 AIO cleaner/wax
    Semper Fi
    Ralph
    Mar 2013
    220
    Will the megs D103 APC be enough to remove most carpet spots or should I still get the Sonax?
    Dec 2012
    Houston, Tx
    1,122
    1) yes and no
    2) yes and no
  10. #10
    Jul 2012
    2,451
    The megs APC will do everything and more the Sonax will.
  1. What am i missing?
    By Blackalak in forum Tricks, Tips and Techniques
    Last Post: 06-11-2016, 10:48 PM
  2. What am I missing?!
    By JamMaster Jay in forum Auto Detailing 101
    Last Post: 11-27-2015, 12:21 AM
  3. Am i missing anything??
    By i_love_my_jeep in forum Auto Detailing 101
    Last Post: 09-28-2010, 05:14 PM
  4. Missing You All !
    By ScottB in forum Off-Topic
    Last Post: 06-04-2010, 10:41 PM
  5. What am I missing??
    By beercanbilly in forum Auto Detailing 101
    Last Post: 08-28-2009, 10:20 AM
