» Detailing Classes
Page 5 of 6 FirstFirst 123456 LastLast
Results 41 to 50 of 52
  1. #41
    Senior Member sudsmobile's Avatar
    Jan 2018
    IE, SoCal
    787
    Re: The Importance and Value of Weekly Maintenance Customers
    Quote Originally Posted by LSNAutoDetailing View Post
    +3 on the bigger tank. I had the small one and the exchange was killing me. Remember they build a delivery fee into the pickup and drop off.
    Quick question. Does your system make waste? I was told that some of these systems use 2x gallons of water to make x gallons of spot free water. Is that true with this system?
  2. #42
    Senior Member Coach Steve's Avatar
    Jun 2013
    Chandler, AZ
    374
    Nope, no waste. RO systems on the other hand, use 3 to make 1.
    **Side Note**
    Don't even get my oldest daughter started on RO systems! OMFG!! She has a Master's degree in Sustainable Environmental Engineering and her field of specialty is renewable water sources and preservation. It's a good thing she's Buddist and practices yoga because as fired up as she gets about the reverse osmosis process and its shameful waste of Earth's most precious natural resource.... Oy!! She'd be inventing new meanings to the word "Postal"
    Namaste, Jessica, NAMASTE!! LOL
  3. #43
    Aug 2016
    109
    I have a awesome customer Iím about to go do his vehicles this morning a 18 650i vert and 18 Rover Sport. I know the garage code. The keys will be in each vehicle and the cash will be in the Range Rover. This will be the 2nd time this week Iíve been out. Usually we do like Tuesdayís and Saturdays. This guy I showed up to his house Xmas morning 2017 I told him I didnít mind I donít have a family. $300 bonus or tip or gift.
    Weeklys are hard to come by. I recommend biweekly and cut them a small discount. Iíve grown my weeklys to the man above and another guy with a trackhawk and Durango SRT. My biweeklys are a gx460, 488,740i, 458, glx etc etc etc
    Repeat customers are key
  4. #44
    Member
    Jul 2017
    El Mirage, AZ
    76
    Got Puretec delivering the 14" tank this Friday. Can't wait to use it for the first time. So question I had, to preserve as much DI water as possible, does everyone else use it for final rinse only or what is your process? My thought process would be, rinse like I normally would, wash 2 bucket method then final rinse with DI water then let the sun dry it? Unless I should use DI water for the initial rinse and bucket wash?
  5. #45
    Senior Member LSNAutoDetailing's Avatar
    Jun 2014
    Chandler, AZ
    3,120
    Quote Originally Posted by Duy View Post
    I use it for the whole process from start to finish. I do mainly maintenance work these days and canít afford nastily AZ water mucking up a car, including my own.
    When I first moved to AZ I didnít wash one vehicle until my tank arrived, which was the second week after moving in.
    Please excuse the typos. Sent from my iPhone using Tapatalk
    Paul_G www.lsnautodetail.com IDA CD-SV
  6. Thanks Duy thanked for this post
  7. #46
    Member
    Jul 2017
    El Mirage, AZ
    76
    I use it for the whole process from start to finish. I do mainly maintenance work these days and can’t afford nastily AZ water mucking up a car, including my own.
    When I first moved to AZ I didn’t wash one vehicle until my tank arrived, which was the second week after moving in.
    Awesome, thanks for the info Paul!
  8. #47
    Jun 2013
    Chandler, AZ
    374
    I choose to be a bit more frugal with the DI water. I use it only for the final rinse - after I have rinsed the soapy water off with city water. I use a lot less water that way.
    Half of my driveway is covered with a 10'x20' canopy that's permanently attached to the ground so I've got that for shade and I also can wash inside my garage with the door closed when it's hot and stay cool because the garage is climate controlled.
    I do use the DI water to wash my pads and I run my towels through a rinse only cycle in my secondary washer that I use solely for that purpose. It makes a big difference. When I foam a vehicle, I usually will use DI water due to the fact that the foam is far thicker and will cling much better.Of course, anything I choose to dillute I use DI water.
    as to your question about just letting it dry in the sun... That's entirely up to you. In my case, unless I've got lots of time, I'll usually blow all the water out of the crevices and any that has pooled on the roof or wherever, and I'll leave whatever water happens to still be attached to the vert surfaces and use it to my advantage if the next step is QDS or Spray wax.
    If I've just finished correcting a vehicle with anything that produces a lot of dust, I'll rinse the vehicle off with DI rather than trying to wipe the dust off because It's a losing battle due to the static trying to wipe it off. Rinsing it ensures all of the dust is gone and provides a static free surface to then do a final wipe with a lint free super plush towel.
  9. #48
    Jan 2018
    IE, SoCal
    787
    Just out of curiosity, did they waive the deposit for everybody here? I said to the Puretec rep "Hey, I read online that if you're not planning on using the tank mobile and it will never leave my home, you guys waive the deposit?" He replied very tersely "Puretec requires a $250 deposit for the tank." Like PERIOD. My guy was not super friendly, seemed like he was mostly reading off a script. Not a deal breaker but I don't like deposits because most places find a reason to keep them.
  10. #49
    Jun 2013
    Chandler, AZ
    374
    Quote Originally Posted by sudsmobile View Post
    My rep was fantastic. He did have to get authorization from someone at HQ to waive the deposit but he went to bat for me and explained that mine was not a mobile business and that the tank would never leave the premesis. They waived it in my case.
  11. #50
    Jan 2018
    IE, SoCal
    787
    Maybe I'll shoot an email up the chain before I sign the paperwork. It was like he wasn't even interested in discussing it. He just cut me off. I swear I have the worst luck getting the same customer service that everybody else gets.
  1. Your Weekly Paint Maintenance Regimen
    Last Post: 03-19-2016, 08:59 AM
  2. Replies: 14
    Last Post: 10-21-2015, 11:19 AM
  3. Giving maintenance care guide to customers
    By LavJordan in forum How to make money detailing cars
    Last Post: 04-17-2015, 06:44 AM
  4. Weekly maintenance prices
    By raysanni in forum Off-Topic
    Last Post: 08-01-2014, 02:57 PM
  5. Monthly maintenance for customers and for yourselves.
    By BMD1904 in forum How to make money detailing cars
    Last Post: 10-20-2010, 10:55 AM
Members who have read this thread: 158
» March 2019
2425262728 1 2
3 4 5 6 7 8 9
10 11 12 13 14 15 16
17 18 19 20 21 22 23
24 25 26 27 28 29 30
31 123456
