Page 5 of 5 FirstFirst 12345
Results 41 to 44 of 44
  1. #41
    Super Member 215Detailing's Avatar
    May 2011
    1,063
    Re: Pressure that draws water from a tank
    Just picked up a new unit for my van Shop Greenworks 2000-PSI 1.2-Gallon-GPM Water Electric Pressure Washer at Lowes.com was about to purchase 1600 psi for $80.00 (Shop Greenworks 1600-PSI 1.2-Gallon-GPM Cold Water Electric Pressure Washer at Lowes.com) normal price $120.00 , but plan to use a foam cannon so most require if correct 2000 psi
  2. #42
    Nov 2016
    KY
    1,065
    I have the 1800 psi electric and it makes foam adequately.
    Shop Greenworks 1800-PSI 1.1-Gallon-GPM Cold Water Electric Pressure Washer at Lowes.com
    Kirk Harrod's Mobile Detailing, Frankfort, KY
    Official Detailer of Camarofest 8 & 9
    No one has detailed more Camaros.
  3. #43
    Feb 2020
    I have never used a pump with my Greenworks pressure washers. My 100 gallon tank is against the bulkhead and I even use a 15 foot hose.
  4. #44
    Super Member sudsmobile's Avatar
    Jan 2018
    IE, SoCal
    970
    Quote Originally Posted by Bluebeachbuggy View Post
    The pressure washer you have has a small pump in it that's why you can also use it as a siphon. Most, if not all, gas pressure washers do not.
  1. Buying a Water Tank, do I need a water pump along with my gas Pressure Waher?
    By 2modfast in forum How to make money detailing cars
    Last Post: 01-05-2017, 01:46 PM
  2. Another Water tank to Pressure Washer thread
    By Mattdamobster in forum Auto Detailing 101
    Last Post: 09-12-2016, 06:12 PM
  3. MOBILE SET UPS (pressure washer & water tank
    By 215Detailing in forum Off-Topic
    Last Post: 11-27-2015, 03:35 PM
  4. Replies: 1
    Last Post: 11-14-2014, 08:04 PM
  5. Water Tank and Electric Pressure Washer
    By KJW Detailing in forum Auto Detailing Tools and Accessories
    Last Post: 11-26-2012, 06:27 PM
