Results 1 to 9 of 9
    Jun 2013
    Montreal, Quebec
    3,996
    Looking for a Ceramic Coating leaflet
    I am gonna start offering Ceramic Coating through a dealership and I need to make a leaflet about the product.
    I am wondering if any of you guys have one already and if so if you could send me a copy.
    I will be using McKee's 37 coating to start with. If there is good demand I might take the training to become Opti-Coat Pro authorized. Will see.
    Anyway, I will adjust the info on the leaflet to match what I will be offering, but I would like to have something to use as a base instead or starting from scratch.
    Super Member FUNX650's Avatar
    Dec 2010
    Ohio, USA
    21,057
    Re: Looking for a Ceramic Coating leaflet
    Quote Originally Posted by Calendyr View Post
    guys have one already...
    the leaflet...but I would like to have
    of starting from scratch.
    Here’s a “leaflet” I took the liberty to
    plagiarize (and doctor-up a little bit)
    from ”OCD’s” website:
    SiO2 Ceramic Coatings (aka Quartz Coatings,
    Glass Coatings, Silicon Dioxide Coatings)
    •Long-lasting protection; very high chemical
    resistance; (Professional options: cured under
    UV for extra strength)
    SiO2 Coatings, sometimes known
    as glass, or quartz coatings, consist of
    nano particles of Silicon Dioxide suspended
    in a hard resin to repel contamination and
    increase shine.
    SiO2 coatings provide a very distinct
    and highly-desired 'wet' look, and require
    minimal maintenance. Most Quartz Coatings
    resist chemicals from the range of pH2 to
    pH11. It also has self cleaning effects,
    delaying the build up of grime on your
    vehicle between cleans.
    -Anti static: helps repel dust from
    the paintwork
    -Resist light swirls: helps to resist
    wash marring and light swirling
    -UV Protection: helps prevent colors
    from fading and oxidisation
    -Easy maintenance: Makes cleaning
    your vehicle much easier
    -High shine 'wet-look' & mirror finish:
    deep gloss & paint clarity
    -Hydrophobic properties: One of the
    most sought-after benefits of coatings,
    promote water beading & sheeting
    -Anti-calcium:
    Help prevent water spots
    -Chemical resistance & dirt-deflection:
    pH11 helping paintwork stay cleaner for longer
    (Professional Ceramic Coatings can have
    different final finishes applied. For example:
    some produces wax-like beading on the
    paintwork to replicate a show wax; whereas
    some sheets water directly off the paintwork.
    _______________________________________
    Note:
    ​-Paint detailing preparation is a requirement
    prior to any ceramic coating. Ceramic coatings
    do not fill the appearance of swirl marks or
    other defects, so these must be addressed
    prior to ceramic coating application.
    -Ceramic coatings should also be applied in
    a controlled environment and allowed to cure
    before they are exposed to the elements.
    ________________________________________
    WHAT AREAS OF A VEHICLE CAN BE COATED?
    •Ceramic coatings are not restricted to paintwork.
    SiO2-based products have properties that are
    beneficial to a range of uses, and specialist
    Ceramic Coatings can be applied to different
    areas of your vehicle.
    -Exterior Trim:
    Silicon dioxide-based products ensures high
    quality half-a-year protection against both
    oxidation of materials and the destructive
    influence of chemicals; UV-damage/yellowing.
    -Exterior Glass:
    Glass coatings repel both water and dirt from
    the glass surface. It repels water for improved
    vision, and reduces dirt, tree fallout, bug and
    bird droppings from sticking to the glass surfaces.
    UV protection aids protection of interior surfaces
    and tinted windows.
    -Wheels (faces and barrels):
    Similar to other SiO2-based coatings, Wheel
    Coating results in limiting the time needed
    to upkeep wheels (especially those with
    complicated designs).
    {For further information:
    Inquire within.}
    Super Member Cruzscarwash's Avatar
    Oct 2015
    Desert of California
    2,425
    jump on fiverr and u can get one mocked up for 5 bucks
    Jun 2013
    Montreal, Quebec
    3,996
    Thanks Bob. I am looking for an actual leaflet though, not really for the text but for ideas on the presentation. I am very good at the technical aspect of creating multimedia material, but I have a very poor artistic ability. I think the right side of my brain is pretty much off So if I could look at pro brochures from Opti-Coat pro, or something similar it would help me come up with a design for my leaflet.
    Super Member FinishingTouchA's Avatar
    May 2013
    Stayton, OR
    677
    Here's the one from Opti-Coat that we use, though I'm not a huge fan and will likely come up with my own soon enough.
    Finishing Touch Auto (Stayton, OR)
    Ryan Hendricks (Owner) 503-602-8483
    FTA Website
    Nov 2014
    149
    I could send you a couple IGL pamphlets if you PM me your shipping address. I have both the tri-fold and also their most recent bifold (I believe).
    Brandon Visser | 269-569-1900 | b5visser@live.com
    Owner/Appearance Specialist | @domainappearance
    Jun 2013
    Montreal, Quebec
    3,996
    Quote Originally Posted by FinishingTouchA View Post
    Thank you for the pictures. Exactly what I was looking for.
    What don't you like about the brochure and what changes are you planning to make in your's?
    So far it's the only one I have seen but it looks good to me.
    Jul 2016
    3,328
    You should email mckees they might already have something. I'm sure you could make 1 if you had to just get some pictures of beautiful cars online, then a couple of paragraphs about how it's the greatest, most wonderful coating ever (doesn't even have to be true) at a 1000% mark up and you've got a professional add copy in your hands. Companies pay big money for those
    Jun 2013
    Montreal, Quebec
    3,996
    Good idea, I will see if I can get something from McKee's.
  1. Replies: 17
    Last Post: 01-05-2021, 07:04 PM
  2. Basic question re Ceramic Coating vs Ceramic Spray Sealant
    By joebruin77 in forum Auto Detailing 101
    Last Post: 12-30-2020, 08:58 AM
  3. Wheel Ceramic Coating Vs Regular Ceramic Coating
    Last Post: 03-28-2019, 02:09 PM
  4. Replies: 12
    Last Post: 02-04-2016, 07:15 PM
  5. WG Uber Ceramic coating or New Gloss coat ceramic forumla
    By Mike@ShineStruck in forum Auto Detailing 101
    Last Post: 12-19-2015, 01:42 PM
