Re: How To: Detail Your Engine Like a Professional
Amazing writeup! I need to get some of those sprayable trim dressings like DP or Chemical guys back to black
McKee's 37 Product Support
Originally Posted by inyadreems
I do most if not all of the preventive steps in this write up when I detail an engine but I use different products such as APC (switching to OPC) and a different brand dressing.
I also use a power washer hose nozzle that is about 2 feet long to get down into the bay.
My question is it is a good idea to have the engine running when using the hose to rinse? I have noticed that local car washes will pressure wash the engine before going thorugh the tunnel with the engine running.
What I like to do is hose, then start the engine immediately and use a leaf blower to dry while engine is running.
I personally prefer to do everything while the engine is off, but I have heard of some people doing what you describe.
I'm an advocate of the saying "better safe than sorry." especially when working on something as costly as an engine.
Looks very good, but the imagination of me pouring water over the LT1 engine in my 95 corvette gives me the creeps. The d***ed Optispark is too unforgiving when it comes to fluids and water.
Any advice what i could do to clean up this engine? Basically any water rinsing is prohibited, because of the Optispark and it's cost to replace it.
Gottchya.
I like to start the engine after hosing and while drying, my reasoning is if if got something vital wet the heat from the engine and combined with the leaf blower will help it dry quicker. Then again running current through an electrical component while wet can fry it.
I might switch to leaving the engine off till done. thanx
Great write-up about an area of the car that is often overlooked!
Curious what kindof mess this leaves under the car when done?
If someone were to do this on a home driveway, would it leave a greasy mess of gunk that a little rain or hose could not remove. Or is it just a bit of dirt that needs to be hosed away?
I'd like to detail my engine compartment, but not sure where I should attempt it.
I did this on my concrete driveway and had no trouble with it leaving a mess on the concrete. I used DP Degreaser and I'm sure my concrete was not sealed at all. I believe the grease is dissolved enough and with the water it rinses right off the concrete.
I have a blacktop driveway with a slight slope. If the drive is wet prior to the engine cleaning process and the dirt/oil pieces are small (not using a paint scraper to remove), the dirt will rinse away. Engines take me a long time and I always feel I can do better. But, look great after a few hours effort. I have had the auto mechanic comment what a pleasure to work on my vehicles.
Last Post: 12-21-2019, 11:37 AM
By UncleDavy in forum How to make money detailing cars
Last Post: 05-10-2018, 07:57 PM
By Eldorado2k in forum Product Reviews
Last Post: 01-01-2017, 02:39 PM
By nodule in forum Auto Detailing 101
Last Post: 10-11-2013, 12:51 PM
By crober53 in forum How to make money detailing cars
Last Post: 05-05-2013, 07:37 AM
