» Detailing Classes
Results 11 to 20 of 37
    Senior Member C. Charles Hahn's Avatar
    Aug 2007
    Lansing, MI
    3,103
    Re: G110V2 cord replacement tutorial w/photos
    Awesome work, Dave! Thanks for the super informative write-up.
    Charlie
    Automotive Appearance Specialist - Serving Greater Lansing, Michigan
    http://www.cchautoappearance.com/
    Senior Member tuscarora dave's Avatar
    Aug 2009
    Etters PA
    5,377
    Thanks Charlie, I figured you would like the write up being a G110V2 guy!! It was fun doing it. Not so often do I have the time to sit here at home and work.
  3. #13
    Mar 2011
    381
    Nice tutorial. It's great to see you share your knowledge about tools and electric stuffs.
  4. #14
    Senior Member tw33k2514's Avatar
    May 2011
    Chicago, IL
    2,298
    Excellent tutorial Dave. I an sure all the owners of the machine will be very happy to see this.
  5. #15
    Jun 2008
    Lawrence
    589
    Very informative! Also, nice trick with the wirenuts. Before I saw that you sealed them I was thinking "Oh no, he's not going to leave them like that." However, I would recommend those who are capable of soldering do that instead and heat-shrink it.
    Then again, if they are that comfortable with soldering they have probably done this already!
    Kevin
  6. #16
    Aug 2007
    Lansing, MI
    3,103
    Quote Originally Posted by aerogt01 View Post
    Only problem with that is I have seen solder joints break under stress/vibration, so over time it could become a problem.
    Nothing wrong with a little clear epoxy.
    Charlie
  7. #17
    opie_7afe
    very nice work! glad to see there easy to take apart!, one tip for the not so mechanically or electrically inclined is when your putting wires into anything that is held down by a screw/screw+plate bend the wire into a U shape and place the wire so when you tighten the screw clockwise it will draw the wire in with the screw and wrap around the screw threads so there's no possibility of those coming off if you tug on power cord or you pull it out of socket by mistake...but great work dave! will help with the hassle of having to send it back and wait. good luck to the guys who will do this repair. one question dave, as my brain is fogged right now isn't it the longer the cord you want to use you need thicker gauge wire? say if for some odd reason someone wants 150ft of cord for a polisher...but my guess is even at 16AWG 150foot would be fine for 5 amps...im wondering why polishers aren't grounded. seems like it would be beneficial but i'm just thinking out loud! i have no clue of electrical engineering, i can solder circuit boards so i guess i have that going for me! guess if my detailing biz fails i can always resort to extracting gold from circuit boards! LOL just kidding about that of course!
  8. #18
    Aug 2009
    Etters PA
    5,377
    Yes that is correct. the longer the cord length the heavier guage you should use. My cords are 14 guage because I run a minimum of 150 feet to get down to my driveway when I detail cars here at the house. I plug into a simple 15 amp circuit in the living room and can run any of my tools with amperage to spare. I once figured out the formulation for running a 10 amp load through 200 feet of 14 guage cord on that 15 amp circuit that included the length of the house circuit to the panel box. My boss figured it out using his little black engineers pocket facts book and there was power to spare so I went with it and haven't had any issues yet.
  9. #19
    Senior Member Bunky's Avatar
    Jun 2007
    Hillsborough, NC
    6,201
    The quick connect crimps style (where you insert the wires into a link and then crimp(compress on wire) )can work as well in lieu of twist nuts or soldering for splicing two wires together.
    Al
    The Need to Bead
  10. #20
    Aug 2010
    Fairmont, MN
    3,188
    Simply OUTSTANDING!
    Your write-up is REALLY gonna help those who have had their V2s poop out.
    Be sure you give your pup an extra kibble or two, she for sure helped you some.
    Bill
  1. Power cord replacement on a metro master blaster
    By KS_Detailing in forum Auto Detailing 101
    Last Post: 04-25-2018, 08:32 PM
  2. G220V2 or G110V2 - Replacement wrench and carbon brushes
    By scoutfai in forum Porter Cable 7424XP Dual Action Orbital Polisher
    Last Post: 04-12-2014, 10:21 AM
  3. [Solved] G110v2 Power Cord Problem
    By nothelle in forum Porter Cable 7424XP Dual Action Orbital Polisher
    Last Post: 05-11-2013, 10:25 PM
  4. Flex 9ft cord or 25ft cord version - Which one?
    By DEXTERITY in forum Auto Detailing 101
    Last Post: 07-26-2012, 11:33 AM
  5. Tutorial: Wetsanding and polishing
    By Anthony Orosco in forum Auto Detailing 101
    Last Post: 03-03-2007, 07:36 PM
» July 2020
