Results 1 to 6 of 6
    McKee's 37 Product Support
    Jan 2011
    7,265
    Talking Clean & Preserve Foam Pads w/XMT Pad Cleaner
    After I've been polishing a car all day I like to make clean up as fast and easy as possible. While I don't always have a pad washer available because I tend to detail my car at a friend's house to take advantage of their garage, I never leave home without a bottle of Pinnacle XMT Pad Cleaner and a Foam Pad Conditioning Brush. I've been using these two products for quite some time now because they work very well to thoroughly clean various types of foam and wool buffing pads. It's such a simple concept that is often overlooked by most, but properly cleaning your pads extends the life so you can get the most out of your investment.
    Pinnacle XMT Pad Cleaner is a penetrating cleaner that breaks up and releases caked on polish, compound, and wax residue from various types of foam and wool buffing pads. It doesn't contain any soap and rinses freely leaving no residue behind that could possibly be re-activated when the pads are used again. Unlike most all purpose cleaners and degreasers, Pinnacle XMT Pad Cleaner doesn't dry out the pad and cause it to fall apart. It performs exceptionally well, especially when used with a Foam Pad Conditioning Brush.
    Look closely below and you can see that the pad is actually white, but it's saturated with Wolfgang Finishing Glaze after polishing several panels. Instead of throwing it in a washing machine which could potentially cause damage to the pad, I went ahead and cleaned it right away while the product was still wet.
    I sprayed the pad with the Pinnacle XMT Pad Cleaner and immediately started agitating it with the Foam Pad Conditioning Brush. Pinnacle XMT Pad Cleaner starts working right away to break down the polish residue. No waiting required with this product. The Foam Pad Conditioning Brush features stiff nylon bristles that make cleaning the pad a breeze. The brush is also ergonomically designed to fit snug in your hand.
    I rinsed out the pad in the sink after agitating it with the Foam Pad Conditioning Brush. Pinnacle XMT Pad Cleaner rinses clean, leaving no soap residue behind because it contains no soap!
    The pad not only looks new, but the texture or the integrity of the pad has not been compromised by the cleaner.
    If you have an extra Grit Guard laying around, turn the pad upside down and let it dry out for a couple hours before storing it with your other pads.
    After the pad was dry I put it away for another day of polishing!
    Pinnacle XMT Pad Cleaner works very well when used in conjunction with the Foam Pad Conditioning brush to properly clean various types of foam and wool buffing pads. It's quick, easy, and performs exceptionally well at its intended use.
    A single 12oz bottle will go a long way and with the durable construction of the Foam Pad Conditioning Brush, you have a winning combination that will last quite a while until you pick up one of these....
    Super Member CEE DOG's Avatar
    Jul 2009
    Florida
    7,358
    Re: Clean & Preserve Foam Pads w/XMT Pad Cleaner
    The product lasts forever
    The way I use it is when I switch pads on my polisher I spray this on and let it sit for 1 minute while I'm priming my new pad. Then I throw it in my pad bucket where I have water and some type of cleaner like DP powder or OPC mixed.
    Here's another method of setting your pads to dry before storing them. Make sure they are completely dry first.
    That picture was from this very old article. Review-XMT Polishing Pad Cleaner
    :dancebanana:
    Sky's the Limit Car Care
    Super Member shoeless89's Avatar
    Jul 2010
    Union, KY
    1,985
    I put my pads on a box fan thats laying at like a 10 degree angle to ensure they are totally dry and speed up the process
    Rule 62: Don't take yourself to d*mn seriously
    Cincinnati, OH
    Shawn
    Super Member kimtyson's Avatar
    Aug 2011
    York, Pa
    583
    Thanks Nick, for a nice, concise post. Another way to spend my hard earned cashola. (Maybe try some APC around that shower stall. Just saying.)
    Administrator Meghan's Avatar
    Mar 2006
    Florida
    15,029
    Nick you have come up with several other uses for the Grit Guard lately, nice!
    It's always good to have multiple uses for one item.
    If you are needing assistance please contact me via email or call.
    Email: Meghan@PalmBeachMotoring.net
    Direct Line 772-247-3483
    Jan 2011
    7,265
    Quote Originally Posted by Meghan View Post
    I even have a Grit Guard in the kitchen at home for when I accidentally go overboard with the eggs when I make french toast!
  1. Clean foam pads?
    By parshooter in forum Tricks, Tips and Techniques
    Last Post: 12-09-2015, 08:23 AM
  2. how to clean foam applicator pads and microfiber pads
    Last Post: 05-24-2012, 06:33 PM
  3. How do YOU clean your foam pads
    By Christopher in forum Auto Detailing Tools and Accessories
    Last Post: 10-06-2011, 07:34 PM
  4. How to clean wax from foam pads
    By Pontiacfan in forum Wool & Foam Buffing Pads
    Last Post: 08-14-2011, 09:01 PM
  5. Best way to clean foam pads??
    By dengood1 in forum Auto Detailing Tools and Accessories
    Last Post: 06-12-2006, 05:26 PM
» October 2022
252627282930 1
2 3 4 5 6 7 8
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 31 12345
