» Detailing Classes
Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
    Senior Member PaulMys's Avatar
    Jan 2014
    L.I. NY
    4,265
    Re: Running water into an attached garage?
    Copper pipes can survive at 32 or a little under with no problem. (For a short time).
    It is that extended hard freeze that will split them.
    Any place that hard freezes should always have a way to drain/shut off, or otherwise winterize the garage installation.
    Sep 2017
    Sweden
    2,124
    Quote Originally Posted by briarpatch View Post
    SWETM.....The basement does not go under the garage....but the garage and laundry room share a common wall. My plan is to split off of the water line(s) for the washer and go directly into the garage. I'm pretty sure I won't have to go outside.
    That's great. What is the lowest temps you have seen in the garage?
    If you use a hose through and take it inside when you a have risk of freezing temperature. You will be fine. But also consider that most houses has self ventilation. And if doing a whole outside to a non heated can mess with the ventilation you have. Also with an antifreeze outlet it's self draining so there is no water standing in the spigot/outlet. So even with some extra bucks it could be worth it in the longrun. I have this antifreeze outlet from the basements bathroom to outside of the house. No need to be doing anything when winter comes and just leaves it as is. And we get very low temperature here but since it's self draining even when the water is on it's no chance to freeze as it's no water in the outlet it self.
  3. #13
    Senior Member briarpatch's Avatar
    Sep 2015
    1,227
    Temps do not get below freezing in the garage. We keep cases of water on shelves out there and they've never frozen. It's rare that we get temps cold enough to cause us an issue with pipes freezing/bursting, but it has happened. Even when those temps occur, it's even more rare that they last more than a day or maybe two. I'll set it up and prep for the worst case scenario anyway.
  4. #14
    Senior Member spazzz's Avatar
    Jan 2014
    Madison
    668
    Well anyway, here is what mine looks like.
  5. Likes PaulMys liked this post
  1. DIY water filter/softener for garage
    By AZpolisher15 in forum Auto Detailing 101
    Last Post: 04-10-2016, 01:30 PM
  2. Running Hot Water Through Deionizer
    By medicscott in forum Auto Detailing 101
    Last Post: 06-20-2015, 07:24 AM
  3. City prohibits running business from home garage
    By Mad Wax in forum How to make money detailing cars
    Last Post: 10-10-2014, 10:26 AM
  4. Garage Water Supply?
    By travis2375 in forum Hot topics & Frequently Asked Questions
    Last Post: 10-25-2013, 10:10 AM
  5. Replies: 3
    Last Post: 06-23-2010, 01:00 PM
Members who have read this thread: 69
» May 2019
